Upgrades for fuel injectors
Old Oct 14, 2016 | 08:41 PM
thatDudeWithaProblem's Avatar
What is a good upgrade for my fuel injectors ? and possibly fuel rail? I have a 2.0 tc and I only had the car for 4 months and I got a check engine for the injectors so I want to upgrade
Old Oct 14, 2016 | 09:11 PM
tomj77's Avatar
Only upgrade there is right now is the opals from zzp. $350 gets u all the injectors and rail. They are bigger so ull need to tune for them.
tomj77's Avatar
What exactly was ur code
Old Oct 14, 2016 | 10:50 PM
P0089 thanks man I appreciate the help
Old Oct 15, 2016 | 11:47 AM
tomj77's Avatar
p0089 is ur fuel pressure regulator I believe, which is in ur high pressure fuel pump, that's what youll need to replace. zzp also has those
Old Oct 15, 2016 | 11:52 AM
Would that cause a small misfire at high rpm's
Old Oct 15, 2016 | 12:57 PM
63 Nova SS's Avatar
What plugs are you running, and what is the gap on them?
How does the car idle by chance. Is it tuned?
Old Oct 15, 2016 | 01:04 PM
ACDelco with a .32 gap and I don't have a tune... At idle I'm good no rpm fluctuations or no shacking
Old Oct 15, 2016 | 05:37 PM
tomj77's Avatar
What cylinder is the misfire in, it could if the fuel pressure isn't high enough. I remember having that code and that's what I did
Old Oct 15, 2016 | 05:50 PM
It don't give me a code but it pops from the exhaust when it's hot like after I push at high rpm's ...So high pressure fuel pump zzp has it for 200 bucks
Old Oct 15, 2016 | 06:29 PM
63 Nova SS's Avatar
It could be several different things. How many miles on her?
Old Oct 15, 2016 | 06:42 PM
43,xxx yeah man I'm thinking...in tank fuel pump , fuel filter, high pressure fuel pump , fuel pressure regular I'll start small
Old Oct 15, 2016 | 07:16 PM
tomj77's Avatar
popping from the exhaust doesn't mean its misfiring, all these cars pop from the exhaust. but yes, hpfp for 200.
Old Oct 15, 2016 | 07:17 PM
tomj77's Avatar
its not the in tank pump, lnf doesn't have a fuel filter, the pressure regulator and hpfp are one and the same.
Old Oct 15, 2016 | 07:19 PM
Ight thanks bro ill get it fix in the next few days
Old Oct 15, 2016 | 09:14 PM
Wait what how's that ... I know nothing about the car I just thought of probable causes
Old Oct 15, 2016 | 09:44 PM
tomj77's Avatar
should probably know the car before listing probable causes. if the in tank pump was not pushing enough fuel, ud have more problems than a fuel pressure code.
Old Oct 16, 2016 | 12:36 AM
Yeah I was assuming I would learn as I go
Old Oct 16, 2016 | 09:26 AM
63 Nova SS's Avatar
But there is no sense in changing parts out that are good unless you have deep pockets. These cars can be pretty temperamental and it may take some trial and error to determine what is wrong. Your issue could be minor and it's important to spell out exactly what's going on with it, and what the conditions are, if we have any hope of helping you.
Old Oct 16, 2016 | 09:58 AM
umrdyldo's Avatar
The very first thing to check is wiring. YOu need to check wiring to the high pressure fuel pump. Need to check the electrical connection plug for the high pressure pump.
Also the giant wire loom that runs along the right side of the engine, it sometimes will come open and rub against the fuel pump.
Ask me how I know. picture is in this thread
https://www.cobaltss.net/forums/gene...-p0089-320825/
Old Oct 16, 2016 | 12:07 PM
tomj77's Avatar
that's the best way, that's how I learned about cars stuff. basically how I learn everything. nothing beats learning via just digging into issues urself. It is expensive sometimes, but forums like this help a lot, is someone else can teach you before you have to spend money, that's always great.
Old Oct 16, 2016 | 03:17 PM
Old Oct 16, 2016 | 07:48 PM
umrdyldo's Avatar
Fuel leak at the metal fitting? Is it tight on there? Do not unscrew it without relieving pressure in the fuel system first. Or it will spray everywhere. Pull fuel pump fuse. Start car until it dies then you can loosen that fitting.
Old Oct 16, 2016 | 08:38 PM
tomj77's Avatar
that's the low pressure side, I usually just put a towel under it and crack it open a little to relieve pressure, but ur way is much better. the fuel system can have a syphon effect though sometimes, iv actually pulled the pump fuse and the car would not shut down, it was pulling fuel from the tank without the in tank pump running. I let it run for 10 minutes before I turned it off, after that I started it again and then it ran itself out of fuel.
Old Oct 16, 2016 | 11:01 PM
Okay so if it's tight what is it like a rubber gasket inside or the actual hpfp I haven't actually removed anything just checked it it was tight
