UPS just left the house
Be careful using ECM boost control if you don't have our tune file. Remember when I was testing different methods of ECM boost control early on, I hit 36.5 psi before I could let off the gas on the dyno. (It made 525 ft lbs.
) Also, I noticed you had a fitting in the top of the gate but not the bottom. If you are using ECM boost control, you will only use the bottom port.
If the waste gate is the same as mine which I'm pretty sure it is it'll have the allen bolts supplied that u fill the holes u don't need with if ur using ECM for boost controll u run the pressure line from the ebc to the bottom I'm pretty sure but idk cus i have a mbc and I just run the pressure line to the bottom and the boost controler line to the top port
I know, but the line is actually pretty far from the manifold and is almost touching the compressor. Ryan what can I do about the meth? And will it be ok to run the car on the current tune till I get it tuned, but just not go wot?
I will have to look at it. Because there is the two air and h2o holes around the center and the one I have it in and the very top one. Am I missing seeing one? And the paper for the wastegate is not very clear from tial but do I have to block the air and water holes off with something?
I would think the two middle cylinders would get more meth than the outside ones. Just seems to me that the air would be moving too fast and the nozzle would be too close to the two middle runners to evenly distribute the mix. idk
