Vac Line?
Old Sep 24, 2009 | 10:38 AM
Projekt's Avatar
Vac Line?
Installing a Mechanical boost guage tonight, can anyone let me know a GOOD vac line to cut into? pics would help
please and thank you !
Old Sep 24, 2009 | 10:42 AM
JPizzle's Avatar
The only one I know, is the one where you tap off for the BOV. It's connected to a little box, and like 2 or 3 other wires...
LOL! I have no idea man. Good luck!
Negrita SS's Avatar
the one form the intake mainfold
Old Sep 24, 2009 | 10:49 AM
Projekt's Avatar
this is going to be fun
a few i can think of that i am not sure are
hose running from the BPV
and there should be a hose from the manifold
pics or ban
Old Sep 24, 2009 | 10:57 AM
LE5_AJ's Avatar
holy **** it's about damn time you're doin this
Old Sep 24, 2009 | 11:10 AM
Negrita SS's Avatar
pics or ban
Old Sep 24, 2009 | 11:17 AM
jefferyss's Avatar
he is not...i am lol
Old Sep 24, 2009 | 11:27 AM
Projekt's Avatar
lies
can you circle the hose on paint so i know please thank you sir
Old Sep 24, 2009 | 12:11 PM
LE5_AJ's Avatar
lulz
lies
doesn't sound like a lie to me :p
Old Sep 24, 2009 | 12:14 PM
Projekt's Avatar
i knowz. jeffs my mechanic lol he breaks strut bolts for me. for absoulutly no charge!!!
Old Sep 24, 2009 | 12:27 PM
LE5_AJ's Avatar
aw that's teh gheyz i want's a mechanic to break strut bolt's for me
Old Sep 24, 2009 | 01:46 PM
JPizzle's Avatar
It should be this one... But please don't quote me.
Old Sep 24, 2009 | 04:22 PM
jefferyss's Avatar
Jordan ...keep it up and im going to *** u in the ass tonight when i see you !
Old Sep 24, 2009 | 05:34 PM
SSlobalt's Avatar
Old Sep 24, 2009 | 07:40 PM
tomj77's Avatar
any vac line going into the intake manifold or the one on the wastegate will work, the one on the bpv i dont think will work. but im not sure. i installed one on my friends civic last friday in about 5 minutes, but he has an external wastegate so it was easy i just used that vac line, but it only reads boost and not vac. but ya, any hose coming out of the intake manifold will give u boost preasure. u know that one that goes into ur lower charge pipe? right beside the map sensor, that will work to. cause u got boost pressure and vac there.
Old Sep 24, 2009 | 07:47 PM
LE5_AJ's Avatar
jp sounds like you have an exciting night in store for you
Old Sep 24, 2009 | 08:27 PM
hiltu's Avatar
my BOV requires a boost and a boost/vacuum source. You can get a boost only from the waste gate actuator. Also i was told you can tap the vac line coming from your TMAP sensor in the cold side piping.
Old Sep 24, 2009 | 11:01 PM
tomj77's Avatar
u can actually tap into any vac line that is attached to any part of the intake system after the turbo. all boost reading is is the psi ur turbo is pushing, and any vac line will do as long as it is connected to the charge pipe / intake maifold. u could even weld something into ur charge pipe if u wanted to and attach a line there. its works pretty simply.
Old Sep 24, 2009 | 11:27 PM
peachpuff's Avatar
Old Oct 7, 2009 | 10:50 AM
Gestapo007's Avatar
is there any benifit to running 2 vacuum sources to a BOV. Have a greddy, running the vac off of the stock BPV, thinking about T'ing in to the intake manifold as well
Old Oct 7, 2009 | 11:03 AM
Terminator2's Avatar
I would say that the BPV line should be more that adequate as a boost/vac source.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SlowSaturn
Sep 28, 2015 11:03 AM
