valve cover breather nipple
Old Jun 26, 2012 | 01:32 PM
paintballerr78's Avatar
I removed the braided lime that's on the back of the valve cover thats on the back left.question is how do I remove the nipple to weld on a bung for a catch can?
Old Jun 26, 2012 | 02:36 PM
Frogstofall's Avatar
Just use fuel line with a clamp. Don't need to weld anything.
Old Jun 26, 2012 | 02:47 PM
tomj77's Avatar
The one that goes to the turbo? U just run a hose from the turbo to catch can and from can to the valve cover. U don't need to weld anything, just slip hose over and use worm clamp to tighten. If ur line is to small to fit, buy bigger hose. I think mine is 5/8 fuel line hose.
Old Jun 26, 2012 | 02:50 PM
ItalianJoe1's Avatar
You have to cut off the steel nipple and remove the rest of it, then weld an aluminum fitting on.
Old Jun 26, 2012 | 05:55 PM
jmarks's Avatar
Just pull them out!
Old Jul 23, 2012 | 10:32 AM
is there a how to on how to remove the valve cover
Old Jul 23, 2012 | 11:19 AM
tomj77's Avatar
Maybe, u take all the bolts off and pull it up, pretty straight forward, just make sure there is nothing in the way
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
SlowSaturn
Sep 28, 2015 11:03 AM
