And the verdict is...
Old Aug 30, 2010 | 10:00 PM
Ryans09SS's Avatar
Bad fuel pump. I had my car go into limp mode sunday before last but with shortage of people and being pretty busy at work, I was having trouble getting done with work with enough time to even drop it at the dealer. I get there friday and they get it in. It had thrown to boost bypass valve codes and 2 fueling codes. They call me today and the fuel pump pooted out with only 21,xxx miles on the car, isn't that a bit early for a fuel pump to go out. Great job GM, anyone else had this happen?
Old Aug 30, 2010 | 10:07 PM
Boxing Fan's Avatar
Warranty. Who cares. Seems to be hit and miss with these cars IMO. People either have problems,, or none at all. I've only owned my car for just over 3 weeks so it's hard for me to comment, but It feels so strong, and well put together I have a hard time believing anything will go wrong with my car.
Old Aug 30, 2010 | 10:26 PM
aweSOMeBalt's Avatar
Been almost a year no problems with my car *knock on wood* except the fail with the rear brakes.
Old Aug 30, 2010 | 10:50 PM
LE5_AJ's Avatar
wait... make sure you check the connector to the high pressure fuel sensor first! i took it to the dealership and that's what they told me so i took it back and found out myself that it's the connector so i had to n. rig it and i'm still waiting after a year for this connector!
Old Aug 30, 2010 | 10:57 PM
jsscooby's Avatar
Mine went out several 1000 miles ago and I currently have 22k ish.
Old Aug 31, 2010 | 04:47 AM
Ryans09SS's Avatar
Yeah, I've had the rear brakes problem too, replaced pads and rotors back in july. Front brake pads still had a good amount of life on them it was kinda stupid to change them too but did it anyway. I get the car back today so I will make sure to check the connector to the high pressure fuel sensor too.
Old Aug 31, 2010 | 09:08 AM
LE5_AJ's Avatar
i mean even if it doesn't look broken if you take the connector off and shake it you can hear the pins inside rattling around
satisfied
Oct 19, 2015 12:35 AM
Boost Fr33k
Jun 13, 2007 08:53 PM
