waste gate flutter
waste gate flutter
Anyone else experience this? My car makes a fluttering sound under partial boost.. Not enough boost to even register on the RPD, but I can hear the turbo spool a little before it does it. According to some subaru forums I found using google search, this is normal. It's only bad if you hear it when you let off the throttle after building boost. My car makes a clean pshh sound with no flutter when I let off under boost. Any thoughts?
I've heard people with K&N's talking about this in the past ..... but I thought it was the bypass valve that was the cause , not the wastegate. If your sure the wastegate is doing this I would check the actuating rod and make sure the locking nuts haven't backed off . When I did the vacuum tank delete it could hear it with the stock air box .... after i put the vacuum tank back in the system it went away.
breds2k
19
Sep 21, 2015 10:24 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
