waste gate flutter
Old Jan 14, 2011 | 12:53 PM
RiceCop's Avatar
waste gate flutter
Anyone else experience this? My car makes a fluttering sound under partial boost.. Not enough boost to even register on the RPD, but I can hear the turbo spool a little before it does it. According to some subaru forums I found using google search, this is normal. It's only bad if you hear it when you let off the throttle after building boost. My car makes a clean pshh sound with no flutter when I let off under boost. Any thoughts?
Old Jan 14, 2011 | 01:11 PM
PrincessTurbo's Avatar
some people cant hear the fluter some can .. I bet almost all have some to a little under light throttle randomly ...
Old Jan 14, 2011 | 01:34 PM
DillySS's Avatar
Your good. I have same issue. I changed out to Dejon spring and nothing changed (it sounds a tad more aggressive) and changed back.
Old Jan 14, 2011 | 02:52 PM
scopedmp5's Avatar
try a heavier spring to hold the gate closed. COMPRESSOR SURGE. forcing air back into the turbo the wrong way. good ear though for hearing it under light boost
Old Jan 14, 2011 | 08:17 PM
rukkee's Avatar
I've heard people with K&N's talking about this in the past ..... but I thought it was the bypass valve that was the cause , not the wastegate. If your sure the wastegate is doing this I would check the actuating rod and make sure the locking nuts haven't backed off . When I did the vacuum tank delete it could hear it with the stock air box .... after i put the vacuum tank back in the system it went away.
Old Jan 16, 2011 | 11:57 AM
RiceCop's Avatar
Can you post a link to that thread?
Old Jan 16, 2011 | 12:04 PM
DoMiStIc_RuSh_06's Avatar
I have this too when I rev my car up an keep the boost gauge in vacuum. When I let off it makes the flutter noise.
Subd for a fix.
turbochargedss2012
Sep 20, 2023 12:17 PM
breds2k
19
Sep 21, 2015 10:24 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
