Wastegate sizing question
Old Dec 10, 2013 | 06:28 AM
raver0789's Avatar
What is the maximum size of turbo I can run with my tial 38mm before I have to go bigger? Don't see myself going lower than 20psi ever.
Old Dec 10, 2013 | 09:05 AM
noorj's Avatar
Alot of factors determine if you'll have boost creep from the wastegate being too small, not just size of the turbo.
Just swap the turbo and watch the logs/boost gauge, if it creeps too much for your liking go bigger.
Old Dec 10, 2013 | 09:12 AM
armcclure's Avatar
Pretty much. There's no set size or power level that equates to wg sizing. Also, the higher boost you run, the less wg needed. So a setup that has creep at 20psi may be perfectly fine at 25+.
Old Dec 10, 2013 | 12:56 PM
Fastgti69's Avatar
The single turbo guys with the 335 are using a single 38mm WG with a 6466. I don't know why they didnt go with a 44mm but they say it works fine.
Old Dec 10, 2013 | 03:23 PM
raver0789's Avatar
But that's on a 3.6 no Lol? I am not sure the size of the 335i motors. I just don't want to experiment. Putting it all together and then no. Doesn't work. Have to take it apart. Just thought maybe someone had experimented before.
Old Dec 10, 2013 | 03:33 PM
Matt M's Avatar
Like they said, it depends on the target boost level. It also depends on the exhaust system and if the wastegate is plumbed back in or dumped external, among other factors.
Old Dec 10, 2013 | 05:15 PM
Nfamous60's Avatar
Wastegate sizing.goes for boost amounts really, normally bigger wastegate for.running lower amounts of.boost smaller wastegate.for.running.high amounts of boost.
Old Dec 10, 2013 | 07:46 PM
raver0789's Avatar
Thanks everyone and Matt M - as usual
Old Dec 10, 2013 | 08:09 PM
Sox-Fan's Avatar
Got Brakes?
I will admit to being a total newb when asking this, but don't you buy a wastegate to match a turbo rather than a turbo to match a wastegate?
Old Dec 10, 2013 | 08:10 PM
BlkWdoSS's Avatar
Im running the TurboSmart Ultragate 38 (38mm) on my cobalt with s366xl @ 25-30psi, VTA, no flutter, no creep
Old Dec 10, 2013 | 08:48 PM
raver0789's Avatar
Lol! How is the lag????
Ya. But I bought a s256et kit made 500whp and now I want more. I went s259 Batmowheel but it didn't work from the factory. So I was thinking of doing something else. If I have to replace most of the kit i will stick with the s256et.
Old Dec 10, 2013 | 08:50 PM
BlkWdoSS's Avatar
lag? what lag? lol, its spools similarly to the 256/259, but thats because of other reasons that I utilize, was really lazy before all of my experiments lol
Old Dec 10, 2013 | 08:51 PM
raver0789's Avatar
Ha! Nos?
Old Dec 10, 2013 | 08:58 PM
BlkWdoSS's Avatar
Nope , no nitrous at all
Old Dec 10, 2013 | 09:01 PM
raver0789's Avatar
So what do you do then to get the lag down? Lol
Old Dec 10, 2013 | 09:08 PM
BlkWdoSS's Avatar
Lots of heat, proper tuning/fueling, and a quick spool valve. Also considering getting rid of FMIC, shortening piping way down and relocating the fuse box so that I can install an air/water intercooler there.
Old Dec 10, 2013 | 09:10 PM
raver0789's Avatar
You running a 3 inch Downpipe and external waste gate? That's my setup
Old Dec 10, 2013 | 10:04 PM
armcclure's Avatar
Funny how many "experienced" tuners miss this part. Especially on e.
Old Dec 10, 2013 | 10:16 PM
JapEatr's Avatar
South Central *********
The quick spool valve only works on turbos with a split exhaust inlet in the housing. Also will not work well with with a split manifold.
Old Dec 10, 2013 | 10:21 PM
noorj's Avatar
I think a lot of that is "tuners" that don't want to be held accountable for a blown motor for quicker spool, when you can easily blame shitty spool on a turbo and not from the tuning.
Old Dec 10, 2013 | 10:55 PM
Nfamous60's Avatar
i run a turbosmart as well great wastegate going with a 17lb spring setup though
Old Dec 11, 2013 | 02:05 AM
raver0789's Avatar
Speaking of spool, has anyone changed the spring in their tial wastegate? What spring is everyone using?
https://www.tialsport.com/documents/w3_tial_38_sp.pdf
Old Dec 11, 2013 | 02:40 AM
cmiller8006's Avatar
I run a 15 lb spring in mine.
Old Dec 11, 2013 | 09:52 AM
noorj's Avatar
I run a 3psi spring lol
I think I need to step my game up
Old Dec 11, 2013 | 03:27 PM
armcclure's Avatar
Honestly, I don't think most of them are that smart lol. 99% tune it like a gas car. Which "works"
Just not ideally. Ask Jon how hard his car hits.
The honest best description I can give is it's like a small pulley m62 with a slight delay in the throttle.
"One mississiWHAM"
