Welded 14' Magnaflow Muffler On
like the title said, but I notice that it is only a bit louder than stock!!?? thought it would be more.
anyway, i just happened to be inspecting the butt weld my mechanic performed on the stock end piece and tip (which he welded to tipless end pipe of magnaflow muff) and noticed a small exhaust leak directly behind where the stock tip is welded onto to stock end pipe by the factory.
At first i thought it was coming from the weld my mechanic did but relaized it was further back towards the end of tip. because of its end location i guess i dont have to worry bout a little air escaping from where tip meets the pipe, right? that wouldn't make the muffler quieter would it??
also, it looks like the tip is sitting a bit low in the factory fender cut out, but i prob imagining that. basically if you put your index and middle finger together , i can slip them in between the tip and top of factory cut out (the index finger stacked on top of middle finger ofcourse)
