What could it be?
Old Apr 15, 2023 | 12:45 PM
AfterShok's Avatar
What could it be?
So I've owned my LNF for over 10 years and I got my engine compression and leak down tested in 2022/2023. The results were the following (double checked at a shop because I thought I performed it wrong)
180psi across all 4 cyl
< 5% leak in cyl 1,3,4
~30% leak in cyl 2
6758, FBO, stock motor with a replaced timing chain as of 20k kms ago
Car pulls hard and runs smooth with no sign of issues. Logs look normal for the most part.
Without tearing into the engine (Will be rebuilding it when i get more parts stock piled) what could my options be for what could be an issue?
Old Apr 15, 2023 | 01:42 PM
Pull the valve cover and make sure a Rocker arm hasn't moved on cylinder 2.
Have you performed an intake runner cleaning?
Old Apr 15, 2023 | 05:56 PM
AfterShok's Avatar
I got my intake valves done in 2022 as in 2021 I had a horrible result in like two cylinders failing the leak down. This cleared the one but the one still has a slight issue.
I've never pulled my valve cover before lol do I need to replace the Gasket? It was replaced last 20k kms ago
Old Apr 16, 2023 | 02:17 PM
Not likely you'll need to replace it, might want to rtv the corners/sharp bends to be sure it doesn't leak
skadeezy96nfp
Forced Induction
Jan 4, 2021 02:59 PM
Area47
May 21, 2014 06:32 PM
turbosmart4
Jan 20, 2013 10:29 PM
Drunkship
Oct 11, 2012 03:18 PM
Xenozx
Apr 28, 2006 01:01 AM
