What do I need to make 350whp (stock turbo)
Old Dec 5, 2011 | 03:41 PM
  #51
2010SS's Avatar
I wish I had more e 85 around here, I only have one station 20 minutes away and I am going to still switch next spring, I am going to keep a 55 gallon drum here lol.
I just keep 6 5 gallon jugs, makes filling up easier, unless your gonna go full e85 then mixtures don't matter
Old Dec 5, 2011 | 08:56 PM
  #52
Frogstofall's Avatar
Out of curiosity, how long can we store E85? Does it need "Stabil" like regular gas does for extended storage times? I was thinking about having 20 gals or so in the garage for emergency use when I make the switch in the Spring.
Old Dec 5, 2011 | 09:27 PM
  #53
cmiller8006's Avatar
Not sure on that. I know if I got a 55 gallon drum it would be ok with how long it would sit. It doesn't last as long as gas I don't think.
Old Dec 5, 2011 | 09:37 PM
  #54
Chevycobaltss3's Avatar
Ethanol gets tons of condensation so leaving it out for a month of so id say itll take in alot of water!
Old Dec 5, 2011 | 09:43 PM
  #55
So do you think a sealed drum would be ok? I have been searching for a couple weeks without a defininite answer.
Old Dec 5, 2011 | 09:47 PM
  #56
I wonder if you could purge the head space in the drum or container with nitrogen?
Also, where do you get 55 gal drums?
Old Dec 5, 2011 | 09:48 PM
  #57
ATLsilverSS's Avatar
find a wholesaler on this list and call them and ask
http://www.iowarfa.org/PDF/E85_value...stributors.pdf
Old Dec 5, 2011 | 09:49 PM
  #58
refer to the link i posted above
Old Dec 5, 2011 | 10:09 PM
  #59
MajorCB's Avatar
Just FYI, I'm running only GMS1 sensors and HP tune -23lbs of boost with 93octane and am right at a stable 295Whp , so I dont see why anyone could'nt make the 300mark easily with just a full exhaust and even just a DP , intercooler.. I dont even think you need the intake to be honest.
Old Dec 5, 2011 | 10:18 PM
  #60
In all honesty ethanol when put into the drum will have some condensation in it because it will have oxygen in it. So I think it can. Will it? Possibly.
Old Dec 5, 2011 | 11:09 PM
  #61
AyrtonSenna's Avatar
I only have a catted DP, Injen intake and custom tune at 20psi. Dynoed 310whp.
Old Dec 5, 2011 | 11:11 PM
  #62
drewbroo's Avatar
shelf life of E85 is 3-4 months, so use it all
Old Dec 5, 2011 | 11:24 PM
  #63
Where did you read/hear this? Why so short? Moisture or something else?
Old Dec 5, 2011 | 11:32 PM
  #64
Moisture and fuel breaks down over time.
Old Dec 5, 2011 | 11:34 PM
  #65
E85 isn't like normal fuel so I thought maybe it acts differently. Does a bottle of vodka go bad if it sits?
Old Dec 5, 2011 | 11:55 PM
  #66
FasterIsBetter's Avatar
I'm going to the closest sunoco 100 station and stocking up on 100 octane next year. Closest e85 station is 120 miles away so might as well stock up on something that won't collect moisture as badly and you can put fuel stabilizer in it.
Old Dec 6, 2011 | 09:39 AM
  #67
RoadconeTuning's Avatar
why not just put a meth kit on the car?
Old Dec 6, 2011 | 11:05 AM
  #68
Because first off Meth is a Lil more unreliable since there is a ton of parts that can fail. If you think you can keep up with the system Meth is fine but its somthing you have to do.....always be aware of what's going on.. also............... **** vodka lol.
Old Dec 6, 2011 | 11:16 AM
  #69
i don't know of any stations that sell any race gas. but the 1/4 track in reynolds sells vp 101 for $9.50/gal up to c16 for $13.50 a gallon..........not something i wanna just drive around on
Old Dec 6, 2011 | 12:44 PM
  #70
drewbroo's Avatar
E10 Ethanol: Recommended engine precautions
E10 is 90-100 days because of the ethanol. So in theory E85 may have even a shorter shelf life.
Gasoline Expiration - Ethanol Blend Fuels Have a Short Shelf Life
Turbo Johnny
Feb 21, 2019 09:41 AM
Canadia
Oct 6, 2015 10:20 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Cptnslo
Sep 24, 2015 09:32 AM
TylerJHowell
Sep 21, 2015 06:47 PM
