what do u need to run e85 on cobalt
Old Oct 23, 2012 | 11:53 PM
BEG4MRC's Avatar
what do u need to run e85 on cobalt ????
Old Oct 23, 2012 | 11:58 PM
BankerBalt's Avatar
bigger injectors. possibly a fuel pump. tune, maybe different plugs
Old Oct 24, 2012 | 12:01 AM
BEG4MRC's Avatar
lnf cobalt
lnf cobalt
Old Oct 24, 2012 | 12:04 AM
BankerBalt's Avatar
derp. i just saw this on the front page. so i believe then, just a tune
Old Oct 24, 2012 | 12:36 AM
Frogstofall's Avatar
Welcome to the forum. What you need is to spend some time reading and searching the forums here. Plenty info here that will not only answer this question but the others that will likely follow.
Old Oct 24, 2012 | 07:49 AM
09CobaltSS1's Avatar
^^ Like frogs said, there is loads of info looming around here, you'll just need to search it out a bit.
Old Oct 24, 2012 | 09:34 PM
jacream_booSSted's Avatar
^what would you possibly know about e85?....lol
Old Oct 24, 2012 | 10:35 PM
hahahaha... true dat
Old Oct 24, 2012 | 10:43 PM
Chevycobaltss3's Avatar
Ethanol is that stuff you buy in the cereal section right?
Old Oct 24, 2012 | 10:48 PM
no, that would be fruit loops
Old Oct 24, 2012 | 10:51 PM
nhanson's Avatar
i thought you just buy a can of corn and dump in your gas tank?
Old Oct 24, 2012 | 10:56 PM
actually a bottle of corn syrup my friend
Old Oct 24, 2012 | 11:05 PM
nhanson's Avatar
High fructose or just regular?
Old Oct 24, 2012 | 11:08 PM
lmao! honestly it all depends on your power goals...
Old Oct 24, 2012 | 11:10 PM
nhanson's Avatar
Better go for high fructose for the extra power.
Does my tune need adjusting after adding it?
Old Oct 24, 2012 | 11:24 PM
SSlobalt's Avatar
You want to run E47, not E85. Actually, if it's your daily-driver, you don't want to run either. It's a pain in the ass if you drive any sort of long-distance in some frequency.
If you do take the plunge, though, E47 is possible with a Trifecta tune or an HPTune from a reputable tuner. You don't need any aftermarket parts. We can't guarantee your injector seals will hold up, unless you're driving a 2010, though.
Old Oct 25, 2012 | 07:54 AM
Cobe's Avatar
what year is your LNF?
Old Oct 25, 2012 | 08:38 AM
reduf99's Avatar
sjc0013 Licks windows
Does the year matter? Or were you just curious? Im just wondering
Old Oct 25, 2012 | 12:04 PM
Troof! While e47 is definitely quite a bit more of a pain in the ass than gas (particularly keeping a consistant blend throughout the year), it is well worth the effort imo as long as you don't mind the extra work involved.
The injector seal issue seems to be far worse with '08 models than any other. I think a couple guys with 09's ran into an issue here or there but for the most part '09 and '10 model years seem to be holding up fine. I forget exactly how long you've been running e47 for, but in my case, in the past 2 years of running ethanol I have had no issues with my injectors or any other seals in the fuel system degrading and/or leaking (knocks on wood).
Old Oct 25, 2012 | 01:20 PM
tomj77's Avatar
So every year had its special issues? 08 injector seals, 09, porus block, how bout the 10s lol
Old Oct 25, 2012 | 01:37 PM
SSlobalt's Avatar
I have an '08, and I ran E85 for 6 months and have been running E47 for the past year with no issues, but I bought a fuel rail from monograt, just in case.
Old Oct 25, 2012 | 01:44 PM
nwss's Avatar
You need e85 cams, tune, and of course e85
Old Oct 25, 2012 | 02:04 PM
Lol.. "e85 cams" huh? That's a new one..
Old Oct 25, 2012 | 02:07 PM
nwss's Avatar
Bfl cams.
Old Oct 25, 2012 | 02:09 PM
prevsrt4owner's Avatar
24 oz. vegetable oil, 24 oz. water, two drops of blood, 1/2 oz. of witch titty. Mix it up, and then throw the concoction into your gas tank. Easy e47. You're welcome.
