whats your coolant temp at?
Old Jun 22, 2009 | 03:06 PM
FF_ace's Avatar
i live in az and i was driving this moring and i see that my coolant temp is at 210. the highest it went was 212. is that ok? what temps do you guys see? thanks
Old Jun 22, 2009 | 03:15 PM
06_SIC_SS's Avatar
mines usually at 178..but i have the s/c not the t/c..
Old Jun 22, 2009 | 03:16 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
My coolant temp hasn't gone above zero in months.
Old Jun 22, 2009 | 03:21 PM
FF_ace's Avatar
ya my car has been down for a month and i just got it back yesterday and noticed it was runing hotter than before. it has warmed up here in phx it was 105 the other day and is only going to get hotter. i was just wondering if that was ok or do i need to get it looked at.
Old Jun 22, 2009 | 03:23 PM
cmiller8006's Avatar
Driving mine stays at or below 192, 85 degrees out. Get on the throtle and it jumps to around 198-200 and drops back down instantly.
Old Jun 22, 2009 | 03:25 PM
FASTL61's Avatar
In AZ nick,they will get that high.mines the same it will go to 217* before kicking the fans on.My moms 07 CTS is the same way
Old Jun 22, 2009 | 03:30 PM
FF_ace's Avatar
ya i figured but i thought i would ask. thanks man. whens the next balt cruze im back in action now well not today cuz its getting detailed
Old Jun 22, 2009 | 03:31 PM
sherm420's Avatar
im usually between 190-200
Old Jun 22, 2009 | 03:33 PM
Terminator2's Avatar
Mine is normally 194* and it is 98* out right now. It jumps to 205-212* when I idle at a light for a while, but it goes down quickly to 194*.
Old Jun 22, 2009 | 03:40 PM
FASTL61's Avatar
Theres one in the works but you know how our cruise s end up
Old Jun 22, 2009 | 03:42 PM
FF_ace's Avatar
mine was 210 when cruzing on the freeway.
off topic: im in search of a new tuner with pyskosteve gone to the military i need a re tune.
Old Jun 22, 2009 | 03:44 PM
FASTL61's Avatar
Trifecta?
Old Jun 22, 2009 | 03:46 PM
I could tune you but you are too far away. Are you on the stock turbo again?
Old Jun 22, 2009 | 03:48 PM
G85 SS's Avatar
178-183 depending on temps outside. I have had them get up to like 218 in traffic in 100* weather before though.
Old Jun 22, 2009 | 03:50 PM
FF_ace's Avatar
ya im back on the stock turbo and just got CIA boost tubing installed
Old Jun 22, 2009 | 03:51 PM
1badBlueberrySC's Avatar
Mine is usually in the 190-195* range but more often than not it is like 187*
Old Jun 22, 2009 | 03:52 PM
rnjmur's Avatar
210 while moving at highway speeds is alittle high. Sounds like the turbo is working overtime.
Old Jun 22, 2009 | 04:16 PM
Bandit1's Avatar
194-199 degrees typically.
Under 203 if sitting too long in traffic or a drive-thru.
Maybe 205 if boosting a decent bit,quickly comes down.
207 is the highest i have ever seen it,and strangely enough that was in the middle of winter with sub 20 outside temps.
Old Jun 22, 2009 | 04:24 PM
ssturbd08's Avatar
191-198 usually, highway it usually stays around 198, the highest i've ever seen it get up too was 212 after runnin on a hot ass day
Old Jun 22, 2009 | 05:01 PM
chevymanva's Avatar
my car stays between the 192 to 204 range with normal driving.
Old Jun 22, 2009 | 05:28 PM
sherm420's Avatar
i reccomend this tune and i cant even use it to its full ability yet
Old Jun 22, 2009 | 05:57 PM
cobaltss86's Avatar
190-199ish
Old Jun 22, 2009 | 06:01 PM
slowstang's Avatar
same here
Old Jun 22, 2009 | 06:48 PM
FF_ace's Avatar
thats what i hear but its kindve hard with me living in AZ.
Old Jun 22, 2009 | 06:58 PM
AnthonyCM's Avatar
hmm highest i've seen is 195 driving around gettin on it a bit in 90 degree weather an 100% humidity
but normally i see 180
