whine from turbo
Old Mar 8, 2009 | 08:43 PM
turbo_chevy_cobalt's Avatar
Originally Posted by M1kl0
your turbo is supercharged.
that would be funny
Old Mar 8, 2009 | 09:18 PM
turbaltss's Avatar
Originally Posted by turbo_chevy_cobalt
it alone happens when it goes over 15 psi even in 5 gear at like 3000 when i go wot.
this really sounds like its just the turbo spooling up...do it in any gear you'll get the same results.....have you started driving with the window down lately its hard to hear it when there closed roll 'em down and it sounds wonderful.
Old Mar 10, 2009 | 01:27 AM
you can hear it spool then it whine i had my buddy drive the car you can hear it real good outside of the car. i guess i need to get my car on a dyno and make a sound clip of it before i replace it.
Old Mar 10, 2009 | 01:33 AM
schamsy's Avatar
Maybe you got some **** in the compressor housing when switching intakes and your messed up the fins in there? I had this problem on my turbo Grand Am...
Old Mar 10, 2009 | 01:46 AM
that might of happened. thanks didnt think about that. but anyway i will be getting the compressor wheel upgrade. so hope that will work. i did find one thing out when it get to 190 in temp is when you can really hear it.
Old Mar 10, 2009 | 09:21 AM
Terminator2's Avatar
i will check into that tonight. but i dont know if that would sound like a whine.
The BPV spring could definately be the problem, but maybe you bearing are going bad. It will get worse over time if that is the case.
Old Mar 10, 2009 | 09:28 AM
i did upgrade that spring
Old Mar 10, 2009 | 09:49 AM
So it is still do that whineing noise? Is it getting worse or staying the same and does it get worse when the turbo spools up to 20+ psi or is it quieter?
Old Mar 10, 2009 | 01:24 PM
Ferretts's Avatar
its a boost leak, i have the same thing... I have the synapse charge piping and it makes the same noise its coming from the coupler that connects turbo and piping...
Want proof? Take some baby powder and put some on the edge of the coupler on the metal but rigth up against the edge of the silicone. Go into your car, rev it to around 6k rpm and watch the baby powder go flying... I am getting new charge piping this spring unless synapse wants to do something about it
Old Mar 10, 2009 | 01:36 PM
That sucks majorly. Contact Synapse about your problem they will take care of it. Or if you want to fix it yourself gets some black RTV silicone and apply to the affected coupler and let dry for 24 hours. Problem solved.
Old Mar 10, 2009 | 01:42 PM
  #36
Ferretts's Avatar
i would rather not "rig" it up and actually have parts that work as advertised, I am gonna go with dejon piping in the spring, i might contact synapse about it, but i need to find time and take pics so i can send it to morgan, so he knows what the problem is so he can not let it happen in future products...
Old Mar 10, 2009 | 01:50 PM
  #37
Watch your hood clearance and make sure you get the T-bolt clamps with the Dejon kit. The silicone thing is not really rigging it it is made of a form of silicone like your coupler just helps it seal better.
Old Mar 10, 2009 | 02:08 PM
  #38
BIGTAG's Avatar
i have a whine from the turbo when it hits about 15 psi. i not sure what it is but it started to happen after i replaced a stock intake pipe that was cracked. mods in sig. i can hear it spool up then the whine. the whine sounds like a little supercharger.
your turbo is blown thats what just happend to me as just a few days after installing my intake i got into it and i heard the whine to i took my intake off and took a mirror and looked at my turbo fins and they were all chewed up and then i found a peace of metal wedged in the fins of my filter
Old Mar 10, 2009 | 02:36 PM
  #39
Where did that piece of metal cone from? Was it inside the filter or outside?
Old Mar 10, 2009 | 03:50 PM
  #40
i will take a look at the fins tonight to see if they are chewed up.
Old Mar 10, 2009 | 04:12 PM
  #41
Ferretts's Avatar
I highly doubt your fins are chewed up... You would notice a huge loss in power before the whining sound... im telling you the turbo to pipe coupler is not on, it is the way synapse makes their piping, it is not a flat mating surface, the pipe sits at liek a 30 degree angle from the turbo and the bead is also at 30, so when you try and put the coupler on it has to be crooked to sit on the bead, but it cant seat right because the coupler is straight and the pipe is off... no blown turbo
Old Mar 10, 2009 | 04:18 PM
  #42
X2.
You should feel a definate vibration and power loss if your compressor is chewed up. I vote boost leak too. I have one where my stock rubber hose comes out of the turbo it has a nice 1/8" cut in it. I still see 20.5 psi so it is not a big leak at all but it does make a little noise.
Old Mar 10, 2009 | 09:46 PM
  #43
BIGTAG's Avatar
it was on the the inside of my filter pretty sure it came from my intake cause it was already powdercoated black just like my intake
Old Mar 11, 2009 | 09:35 AM
  #44
if there is a leak after the maf sensor it throws a code.
Old Mar 11, 2009 | 09:44 AM
  #45
Not if the leak is minor. Mine leaks at the chargepiping a little. The stock rubber hose blew out and has a 1/8" long tear in it. No codes in 500 miles of driving. Either you have leak, bad bearing in the turbo, or the fins of the compressor are damaged. Can anyone think of any other options?
Old Mar 11, 2009 | 12:11 PM
  #46
i will look into all these tonight last night a worked to late but see what i can find.
Old Mar 11, 2009 | 12:25 PM
  #47
Let us know what you find.
Old Mar 11, 2009 | 01:18 PM
  #48
Hawaiian Whore's Avatar
i don't think it's a boost leak... i think it's the bearing inside the turbo making the sound... my car does it, but i'm still spiking 25 holding 22 w/o any probs
Old Mar 11, 2009 | 01:20 PM
  #49
blackrocky's Avatar
how are you getting 25lbs. whats done to your tc?
Old Mar 11, 2009 | 01:23 PM
  #50
Mine is tuned for 20.5 psi but it spikes 24-25 psi for a split second before it settles down to 20.5.
