Whistling on high boost
If the whistle noise you hear sounds like my car then its a boost leak.
Video Link: http://youtu.be/grnHCfESa_0
Dont really understand it either, Like I said, after replacing the intake mani, and injector seals. Mine stopped. So, it could of been a number of things, I have my theories of course. I will let every one know if i can get it to go away after doing dome fueling mods soon. Ive yet to take anything off my stock LDK
As long as your car is correcting for fueling and keeping your fuel trims close to 0.0 +/- 5.0, and your peak boost is where it should be, then your fine. worse that could happen is the turbo is working just alittle bit harder than it needs to. no big deal. Ive see dummies with large openings flooring it trying to figure out why they dont generate boost, meanwhile there turbo is losing its **** lol. normally the check engine light will take care of that but it its been deleted/disabled....
Mine does this exact noise. of note, I didn't hear it until after I installed my k&N SRI recently. all connections have been double checked. I was thinking it was normal just now audible with the SRI?
You think it could be a cracked turbo or something? Or bad install and it's leaking unfiltered air?
To me, mine sounds like a normal turbo. I am confident and will keep rocking that sweet sound.
Check out this vid. It's neat all the cool sounds the car makes up front.
Memorial Day @ Laguna Seca - 2009 Cobalt SS - YouTube
Video Link: http://www.youtube.com/watch?v=q-BjF21ufTA
I was running GMS1 and had the exact same noise. Making 20psi was almost impossible. I tightened the coupling going to the TB and re-oriented the GMS1 boost sensor on the lower charge pipe so it would not contact anything. Sound went away after that and I could feel that the car had more power and was more responsive. You can hear the "before" in the vid. I have a K&N SRI btw, that's where you hear the blow off from.
and auto x of course.
