Whistling on high boost
Old Nov 12, 2013 | 07:49 PM
stealthy1ss's Avatar
If the whistle noise you hear sounds like my car then its a boost leak.
Old Nov 12, 2013 | 08:02 PM
500 Abarth Dyno - YouTube
That your Abarth?
Old Nov 12, 2013 | 08:15 PM
Originally Posted by ECaulk
That your Abarth?
Yep. Made 194whp 208wtq with just an intake and a boost leak. All of them have boost leaks.
Old Nov 12, 2013 | 09:54 PM
TCBalt09's Avatar
Video Link: http://youtu.be/grnHCfESa_0
Hard to tell on my phone. Mostly hearing exhaust. So what if it is a boost leak and i fail to correct it?
Old Nov 14, 2013 | 11:13 PM
kzak104's Avatar
It's not a boost leak. All Cobalts do it. Unless there is a factory boost leak... Different car. Could make the same sound for a different reason.
Old Nov 15, 2013 | 11:37 AM
PrincessTurbo's Avatar
Originally Posted by TCBalt09
I dont get how this didnt happen on my old turbo but now it is happening
Dont really understand it either, Like I said, after replacing the intake mani, and injector seals. Mine stopped. So, it could of been a number of things, I have my theories of course. I will let every one know if i can get it to go away after doing dome fueling mods soon. Ive yet to take anything off my stock LDK
Old Nov 15, 2013 | 11:40 AM
This is actually a very good representation of the noise. unfortunately , if its not found in your boost tubing , Its going to be very hard to track down. My tubes are perfectly fine after pressure testing them so it must reside somewhere in the manifold.
Old Nov 15, 2013 | 03:43 PM
CudaJoe's Avatar
As long as your car is correcting for fueling and keeping your fuel trims close to 0.0 +/- 5.0, and your peak boost is where it should be, then your fine. worse that could happen is the turbo is working just alittle bit harder than it needs to. no big deal. Ive see dummies with large openings flooring it trying to figure out why they dont generate boost, meanwhile there turbo is losing its **** lol. normally the check engine light will take care of that but it its been deleted/disabled....
Old Nov 16, 2013 | 06:18 PM
TCBalt09's Avatar
To help explain, i took this video.
Old Nov 16, 2013 | 06:22 PM
TCBalt09's Avatar
The noise is at around :25
Old Nov 17, 2013 | 10:36 AM
  #36
TCBalt09's Avatar
Anybody watch this video? Thoughts?
Old Nov 17, 2013 | 11:58 AM
  #37
SSedanMan's Avatar
Mine does this exact noise. of note, I didn't hear it until after I installed my k&N SRI recently. all connections have been double checked. I was thinking it was normal just now audible with the SRI?
Old Nov 17, 2013 | 12:38 PM
  #38
Shanedude's Avatar
Yes normal k&n sri sound.
Old Nov 17, 2013 | 12:40 PM
  #39
TCBalt09's Avatar
I have had the knn for years and didnt hear this sound until my turbo was replaced last month. Blows my mind
Old Nov 17, 2013 | 01:01 PM
  #40
Shanedude's Avatar
That is weird. Maybe you weren't making optimal power with the old turbo? The whistle only comes higher up in the RPM. It grew louder going from GMS1 to Trifecta.
Old Nov 17, 2013 | 02:50 PM
  #41
TCBalt09's Avatar
Hmmm then again I have only been tuned for about 2 months now.
Old Nov 17, 2013 | 03:25 PM
  #42
SSedanMan's Avatar
just fyi I have been tuned with Trifecta 22psi for about a yr. now. only other mods are DP and exhaust, so stock pipes as well.
Old Nov 17, 2013 | 03:36 PM
  #43
TCBalt09's Avatar
So im seeing it as common, but being common doesnt answer if its normal. Scared to go WOT lol
Old Nov 17, 2013 | 04:11 PM
  #44
Shanedude's Avatar
You think it could be a cracked turbo or something? Or bad install and it's leaking unfiltered air?
To me, mine sounds like a normal turbo. I am confident and will keep rocking that sweet sound.
Check out this vid. It's neat all the cool sounds the car makes up front.
Old Nov 17, 2013 | 05:01 PM
  #45
Sonicyeller's Avatar
Memorial Day @ Laguna Seca - 2009 Cobalt SS - YouTube
All the sounds in that video sound normal to me. Awesome vid BTW. Must have been a lot of humbled drivers there that day after they had to let a Cobalt past. Some of those guys have horrible driving lines though -- I've never driven Laguna Seca in real life, but I have a really good idea of the best line from all the times I've driven it in video games.
Old Nov 17, 2013 | 05:22 PM
  #46
TCBalt09's Avatar
Video Link: http://www.youtube.com/watch?v=q-BjF21ufTA
Dude that turbo was working! Bet it was nice and cherry red at the end
Old Nov 17, 2013 | 06:38 PM
  #47
Shanedude's Avatar
Naw wouldn't be that red haha. And he is only GMS1 in vid.
Old Nov 24, 2013 | 09:35 PM
  #48
Miko's Avatar
I was running GMS1 and had the exact same noise. Making 20psi was almost impossible. I tightened the coupling going to the TB and re-oriented the GMS1 boost sensor on the lower charge pipe so it would not contact anything. Sound went away after that and I could feel that the car had more power and was more responsive. You can hear the "before" in the vid. I have a K&N SRI btw, that's where you hear the blow off from.
Old Nov 24, 2013 | 10:04 PM
  #49
kzak104's Avatar
mygod that looks fun. we only have 1/4 mile and a flat track here
and auto x of course.
Old Nov 24, 2013 | 10:19 PM
  #50
Shanedude's Avatar
Yes I have never been to a track either but would love to next year since i'm off warranty now.
