Who has Hahn lower CP, GMS1 and rotated mounts?
Old Aug 4, 2012 | 03:15 PM
colodude18's Avatar
I have the GMS1-specific Hahn lower CP, and I believe that since I installed Powell's rotated mounts, the lower MAP sensor connector interferes with the AC connector. The latter rubbed all the way through and I can't seem to find a position for the lower CP where the two connections don't interfere with one another... Here's a picture of what I'm dealing with. I tried re-positioning the lower CP on both ends, but the "play" doesn't seem to be enough for the connectors to clear each other. Any ideas??
As seen from the top:
As seen from the bottom:
Old Aug 4, 2012 | 05:11 PM
Powell Race Parts's Avatar
I would suggest rotate towards the rad shroud you can slot the rad shroud for more space. We have done that on some early hahn pipes.
Later pipes I have installed dont seem to have an issue.
I talked to Hahn about it, he has no clue about rotated mounts, and no intention to do anything as he pre makes syatems in batches; so just like his exhaust systems that crash into the rear beam, you are on your own to figure out a solution.
Old Aug 4, 2012 | 05:25 PM
SSlobalt's Avatar
1) Remove Hahn lower charge pipe.
2) Throw Hahn lower charge pipe in trash.
3) **** on Hahn lower charge pipe.
4) Re-install stock lower charge pipe.
5) Drive away happy and P0236-less.
Old Aug 4, 2012 | 05:29 PM
colodude18's Avatar
I talked to Hahn about it, he has no clue about rotated mounts, and no intention to do anything as he pre makes syatems in his in batches; so just like his exhaust systems that crash into the rear beam, you are on your own to figure out a solution.
Thanks John! I read about turning the sensor around but I don't like cutting up the fan shroud; I thought this was why the modified lower CP was designed, apparently they didn't move the sensor over far enough... I might just end up getting another brand lower CP, or (short term) go without AC...I've been doing that since spring and the worst heat should be over ;-)
Old Aug 4, 2012 | 07:09 PM
ZZP charge pipes fit well. stock works for me as well, but the plastic nipple can break off if folks pull on it.
Old Aug 4, 2012 | 07:29 PM
Dart_SI's Avatar
its funny how a few years ago everyone was all like "zomg hahn is so high quality awesome!!!"
i run the stock lower cp. no problems for me.
Old Aug 4, 2012 | 10:17 PM
colodude18's Avatar
lol at pissing on the Hahn lower CP
I actually might just throw the stock pipe back on. I've been getting a **** ton of P0236s lately...
Reason I replaced it was that I heard from two people that blew the plastic piece on it running E85. I guess it's time to put that theory to the test...
Old Aug 5, 2012 | 10:49 AM
Sonicyeller's Avatar
My stock upper pipe survived 27psi spikes and steady 25psi on an E85 tune for almost 6000 miles. It was fine when I took it off and replaced it with an Injen. I'm sure the stock lower pipe will be ok.
Old Aug 5, 2012 | 10:53 AM
Dart_SI's Avatar
i have ran 29 PSI with the BNR through the stock lower CP. its not going to blow.
Old Aug 5, 2012 | 06:17 PM
colodude18's Avatar
Yeah I think I'll slap it on one of these weekends. I'm running a 26PSI Terminator E85 tune, and have managed to explode (implode) my vacuum tank at a track day already (which I've since bypassed on track days) We'll see how the stock lower CP holds up...
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
maliki778
Oct 1, 2015 07:39 PM
nathan112i
Sep 30, 2015 07:12 PM
