WHP Thread
Old Feb 16, 2009 | 04:36 PM
Cobaltss/TC's Avatar
Originally Posted by Terminator2
Thanks man, why so rich, my car started losing power when we pushed the A/F below 12.5 or so so we left it at there or a little leaner. I guess better safe than sorry just watch your cat converter it will run hotter the richer you are. It reacts with all the extra nitric oxides and other waste products in the exhaust gas and those reactions produce all that extra heat. That is why the car does that funny high idle cat warmup thing everytime you cold start it to warm the cats up faster it injects fuel on the compression stroke to richen the mixture up and heat the cat up faster. Just something to keep an eye on.
No haven't had any issues with any of that, we adjust cam timing same with spark timing so that changes things there, i watch the cat temp since our ECM calculate the temp of the cat based on the amount of fuel being sent into the echaust stream never gets above 1200f so it is cool.
Old Feb 16, 2009 | 04:50 PM
Terminator2's Avatar
Hey whatever works. as long as you are not seeing 1700* temps that is all that matters. Did you make more power in the low 12s than the mid to high 12s, or did he just keep the A/F that rich the whole time at 22 psi?
Old Feb 16, 2009 | 05:12 PM
It seems like i made more hp and tq in the low 12s it gets there quick cause the turbo spools quick, first gear i think is the only exception cause i have a boost limit of about 7-10psi in 1st
Old Feb 16, 2009 | 09:06 PM
Black02LS1's Avatar
Why do you have it set to low boost in 1st? So it doesnt spin the tires?
Old Feb 16, 2009 | 09:15 PM
yeah i want to be able to use my first gear lol, also pointless cause you are not in 1st for very long just a crappy gear for a lot of boost, i was also having issues with the damn thing on hills cause i live on a damn mountain pretty much and when ever i needed to move when i was stopped on the hill it would boost to high given me a hard time
Old Feb 16, 2009 | 10:52 PM
Black02LS1's Avatar
Yea spinning on hills isnt a good thing. How much money have you put into it to get up to 315 whp?
Old Feb 17, 2009 | 01:30 AM
Well you can get close to that mark with just a tune which my case was 250. I have a special tune so if i were to get the full boar tune it would be more like 330whp with all my mods but i have to wait to get a new clutch tell i do that.
Old Feb 17, 2009 | 01:54 AM
ajjaro's Avatar
Originally Posted by andrew97
i made 225 whp with 3" cat-back and k&n intake. Hopefully make close to 300 with ott stage 1, jbp header, and the meth kit i have.
if you want ot get near 300 you'll have to drop down to a 2.6/2.5 pulley and run strong meth mixture 70/30+ with other extra cooling mods
get a downpipe also
Old Feb 17, 2009 | 08:35 AM
Yep. The richer mixture will load up the motor sooner causing the turbo to spool up a little quicker. I will try a little richer mixture next time I go in for more tuning it may help once I have all my bolt on mods done. I am hoping to see 320-325 whp with timing tables I have in my car. I am also going to do a comparison to see how much of a difference in power there is between my timing table and the stock settings becasue there are a lot of people out there on the stock timing I want to see how much of a difference it makes. I am betting there is a 15-20 whp difference there.
Old Feb 17, 2009 | 03:08 PM
Black02LS1's Avatar
How many of you still have a valid warranty? Wont retuning the car void warranty?
Old Feb 17, 2009 | 03:10 PM
  #36
hatrickstu's Avatar
wait is there two of these threads now? wtf
Old Feb 17, 2009 | 03:21 PM
  #37
Rissa's Avatar
Regional dumb dumb, he wants to know what us So Cal people have lol.
Old Feb 17, 2009 | 03:54 PM
  #38
gomy_ss's Avatar
2009 Cobalt SS/TC 293 whp and 330 lb-ft, bone stock only tune by Trifecta
2007 WRX T/R 305 whp and 373 lb-ft with some upgrades
  #39
gomy_ss's Avatar
Old Feb 17, 2009 | 04:31 PM
  #40
Yeah well i work at the dealer and they know that **** won't fly by saying that voids the warranty. So people can find really cool dealerships but most of the time you are screwed
Old Feb 17, 2009 | 04:44 PM
  #41
DNewman's Avatar
A tech at my local dealership told me that as long as I return my ecu back to the stock tune I will be fine, so when I ordered the Trifecta Tune I purchased the data cable.
Old Feb 17, 2009 | 05:16 PM
  #42
Good idea, the only ECM we have ever checked for proper calibrations are the Duramax engines because if you tune those guys there can be issues because some of those guys go way to extreme
Old Feb 18, 2009 | 12:39 PM
  #43
Black02LS1's Avatar
Lol, well how else are you going to get a full sized Duramax to do low 11's in the 1/4!
Old Feb 18, 2009 | 12:53 PM
  #44
80 psi anyone?
Old Feb 20, 2009 | 09:17 PM
  #45
Hugger1975's Avatar
sig!!
no cobalt dyno yet
Old Feb 20, 2009 | 09:31 PM
  #46
Baldturbofreak's Avatar
80 psi anyone?
When it comes to diesels increasing the boost does little for power output, unless your injecting more fuel then there is availible O2 to burn (black smoke)
It's like from holland veird.
Old Feb 21, 2009 | 09:39 AM
  #47
Injecting so much diesel fuel that the car behind you cannot see FTW.
Old Feb 22, 2009 | 07:55 PM
  #48
slowstang's Avatar
I'm hoping for 480-500whp and 600wtq...
out of the mustang
Old Feb 23, 2009 | 01:33 AM
  #49
Black02LS1's Avatar
out of the mustang
What kind of mustang?
Old Feb 23, 2009 | 09:58 AM
  #50
Hugger1975's Avatar
out of the mustang
Why isnt it in your sig?
