why no strokers
I was into DSMs in highschool and a big upgrade was the 2.4L stroker. The only issue was that you needed to reduce the Redline of you could actually nick the block with the rods. But with the increased displacement people just used bigger turbos to make ridiculous power from about 4k to 6k. I think most were seeing 450 - 600 within that range depending on fueling turbo and tunning. The increased displacement helped spool the larger turbos faster plus they made more torque down low.
and of course you can make the same peak numbers without it.. it's area under the curve that matters..
Actually BTF already have one. His customer (JAMES) with a GT35r turbo LNF solstice has rod and piston combo that allowed him to use the LE5 crankshaft (98mm stroke) producing 2277cc's.
He has a Darton MID sleeved block that opened it up to 88mm for a 2.4L torque monster
BTF offered me to have a stroker kit as well.......but I declined, since I'm going for a compound turbo set-up
According to the GM Handbook. The difference between the 2.4L and 2.0L is bore and stroke.
2.0 LNF bore = 86mm Stroke = 86mm Forged
2.4 LE5 bore = 88mm Stroke = 98mm Cast
Everything else is the same
The rods are the same and it makes no mention of the block height. It does say that the LNF uses 8 bolts and the LE5 uses 6. It shows that the upgrade point of the crank is 500HP
Ok so it does work then the way I thought. Like the DSM guys did it. 2.4L crank with different pistons. Usually shorter.
you mentioned that he sleeved it. I would like to see if we could do it with out sleeving.
at 2.27 we have gained almost 15% more displacement.
This is probably not worth ripping your engine apart for this but It would be a nice option if you were going to be doing a rebuild anyways. 15% is 15%
am I missing something here?
I think making a 2.3L would be cool, but why not just change out the LNF shortblock for an LE5, and have some custom pistons made ~ wouldn't that just be easier?
being of old school mentality, I've been waiting to read of short block modifications, and cam swaps... but so far haven't heard of jack squat on either end.
I know pretty much every engine I am aware of sees gains from cam swaps, but it seems that CSS.net members all think that the variable cam phasing means that lift or duration changes are useless...
yeah, right.
I had understood that the LNF block, is essentially the LE5 block, but with smaller a bore.
I had read that the L61 & LSJ are essentially the same block, while the LE5 was a revised/updated block that started from the L61/LSJ casting, and that the LNF was a variant on the LE5 casting...
The "Gen II" block is similar to the 2.4 L and also features VVT technology. The Gen II block was developed using data from racing programs and computer simulations. The bore walls and bulkheads were strengthened with a weight increase of 1 kg (2.5 pounds). The coolant jackets were expanded to improve heat rejection, resulting in a coolant capacity increase of 0.5 liters.
yeah, right.
383 Strokers, 409 , 427 BBC. I've tweaked a lot with these.
Barely ever hear about it here.
According to the GM handbook the rods and cylinders don't need to be upgraded till around 400HP where the pistons are at 300HP.
With that in mind if we could use the LE5 block with forged pistons and LNF rods then we would have a 400HP stroker motor for about 1,500.
And yes we can make the same HP out of the stock block but this block would allow for a wider powerband while still being fairly price friendly.
On another note looks like we would have to use the LE5 flywheel because of the bolt patterns.
Yeah I will probably wait to see what they do with their stroker kit.
I would like to build one on the side though. I have found used LE5s locally for 500-700
But I would have to custom order the pistons from Wiseco so that kinda sucks.
I could be wrong - but this is just what I have understood to date...
on a side note, I haven't a clue if hte newer LAP uses the same L61 block, or some varaint of the gen II block either...
Frankly I'd be surprised if the crankshafts use a different bolt pattern for the flywheel;
I could see a different sized clutch depending on the engine, but I'd think the flywheels should interchange. This seems to be the way that GM normally does things.
BTW the Sky LNF flywheel is close to 35 pounds. Sky888 can you chime in I think you have an aftermarket flywheel.
I found out Wiseco does make the pistons already. They are for an 88MM bore
Part # is K635M88 Price is about the same as the standard bore.
SO I think I can start working on a parts list.
1. LE5 block
2. LE5 flywheel
3. Wiseco K635m88 2MM over sized (GM says we can resue the stock rings)
4. LNF Rods
A clutch will probably be needed with the new flywheel can someone with a 2.2 or 2.4 chime in
