Wideband...
Old Jun 6, 2009 | 09:09 AM
cobaltltblue's Avatar
Wideband...
I was digging through my shed and came across a Home built Narrow band AFR Meter i used back in the day to tune my Daytona Shelby. It worked good with a bleeder to go from factory 12 to 18psi. Well it got me thinking..... Our cars have a Wideband in them factory right? So can't we splice into the line with a Wide band gauge then save the cost of a Wideband o2 sensor and welding our exhaust?
Old Jun 6, 2009 | 09:13 AM
redcomet303's Avatar
you could tap onto the signal if you had the correct wideband reader it will not work with a narrow band gauge. or you could buy an aeroforce interceptor or any other scan gauge.
Old Jun 6, 2009 | 09:22 AM
peachpuff's Avatar
Narrowband sensors have a voltage output, widebands dont. A wideband controller takes all the outputs from the wideband sensor and turn's it into a readable signal, which is basically what our ecm is doing. You're going to need either a aeroforce/dashhawk/dashdaq to read the wideband through obd2.
Old Jun 6, 2009 | 09:24 AM
Sweetsandman's Avatar
Don't forget the Aeroforce Interceptor reads WideBand as well.
Old Jun 6, 2009 | 09:36 AM
OH thanks guys i totally forgot about those type of readers. Thanks a bunch i will look into those.
elecblue06
Nov 22, 2011 06:55 PM
volsfan92
Sep 27, 2011 02:41 PM
volsfan92
Sep 26, 2011 08:56 PM
cardelino18
Nov 24, 2010 01:04 PM
r0k0
Dec 2, 2007 06:45 PM
