winter is here so starting my build
ok i have a 09 ss and im gonna build it since winter is here and iv got my truck back so no need for the car for a bit. im hoping to be in the high 400s low 500s on pump gas. for now my only definite thing im doing is zzps bolt on turbo i believe its called a zfr. im looking for everyones input on what brands and mods to get, i need a bigger intercooler, better clutch, upgraded axles, zzps fifth injector, and what else. anything you got in mind let me know and what of each should i look at
thanks for all your help everyone
i was talking to the guy with that crazy ass cobalt that took on the skyline and he told me to get that turbo he said it should put me in the range im looking with the right mods
im pretty set on zzps turbo i like the bolt on idea makes the whole idea a bit easier, i just went through hell putting a new turbo setup on my truck and it was a huge pain so bolt to me = easier
Well I just finished my build. I have the Pwerks WR-3 proto and a built motor, supporting mods etc. I will be very hard to get to 500 on pump gas with the ZFR. More then likely you will be at the 450 range with an aggressive tune. We are in the testing stages of the WR-3, but I can tell you that it will contend with the ZFR and is also bolt on
^ zfr isn't able for 500 unless u had serious fueling and aggressive tune overpriced in my opinion better off getting a 58/57 or 55/57 for 800$ t3/t4 manifold from zzp or treadstone or wherever, external waste gate valve springs and a clutch ull be good for mid to higher 400's all day
my overall idea was get the parts that would make me 500+ on the motor in the car on a less aggressive tune, and put to together a 2ns motor on a stand to put all the parts on and turn all to power up
Intercooler: Treadstone, ZZP, Turbo XS, Pwerks, Hahn (not in order fo quality they all great products)
Clutch: ZZp, Spec, Ky
Axles: you dont need them you have a LNF they are pretty beefy
5th injector kit: you should get depending on your power goals
ZFR; could be on bakorder i think not to sure but if this is yoru turbo of choice dont think you need a 5th injector kit/ do you plan on running a E tune?
then obviously exhaust, intake, chargepiping, forge BPV, tune, sticker tires lol and some retros
