wiring Gauge??
Old Mar 7, 2012 | 03:30 PM
Geo_SS's Avatar
wiring Gauge??
just an oil pressure gauge and want to hook it up to the dimmer switch?? i dont wanna short anything out thats why im asking to be safe, but which wire is for the power. that way i can also dim my gauges and i know for ground there is metal under the steering wheel.
Old Mar 7, 2012 | 04:11 PM
Geo_SS's Avatar
Old Mar 7, 2012 | 04:16 PM
SSlobalt's Avatar
There's no current draw to speak of from a gauge. 18 should be fine.
Old Mar 7, 2012 | 04:22 PM
Geo_SS's Avatar
i have the mechanical one where u see the oil through the lil tube i wanna connect it for the light bulb to light up the gauge
Old Mar 7, 2012 | 04:30 PM
tomj77's Avatar
dude, why would u get a mechanical one? its not a good idea to have an oil pressure tube in the cabin, thats asking for a mess. or fire. thats why in alot of race cars they are mounted on the hood.
But to answer ur question, get a multimeter and test the wires to ur stock boost gauge. all u gotta do is test each wire, turning the lights of the car on and off, the right one will get power when the lights are turned on and will loose power with the lights off. to be sure, turn the dimmer and the current should rise and fall from about 4v when dimmest to about 12v when brightest
Old Mar 7, 2012 | 04:39 PM
Geo_SS's Avatar
I know the where abouts of a gauge like that but I wrapped it to be more secure.. And I don't really run my car like a race car.. But I get wat ur saying..
Ok cool thanks dude and I'll try that out..
Old Mar 7, 2012 | 04:52 PM
Boosted4's Avatar
According to my Haynes manual, the dimmer switch is hot at all times from the BCM via interior light fuse #27. The dimmer "signal wire" is dark green, and the "low ref" is purple.
Old Mar 7, 2012 | 05:37 PM
Geo_SS's Avatar
thanks this helps alot.
and one more question i tested it out and the pressure drops to like 20psi when hot and when im accelerating it only hits 50 and goes back down.. did i connect it in the wrong place??
i have it on the drivers side up top on the in the head?
Old Mar 7, 2012 | 05:40 PM
Geo_SS's Avatar
So then i would connect the positive from the gauge to the dark green??
sorry im new to this
Old Mar 7, 2012 | 07:01 PM
tomj77's Avatar
if id remember the wire id tell ya lol been a long time
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
Sep 27, 2015 08:53 PM
