WOT Box Install on LNF
Some people needed the info so I took pics as I pulled mine off. Hope this helps you out
First 2 wires are the APP and CPP wires, they are located at the VCM, large connector closest to the driver's side of the car:
Next wire is the IGN3 Control wire, this is located at the VCM, large connector closest to the passenger side:
Finally is the IGN Power, this is the front bundle of wires coming out of the side of the fuse box. Its the ONLY Pink/white wire, check the instructions for which red/black goes to the box or the coilpacks. Mine both look red here and I forget off hand!
yes the NLS is the same thing. But with the WOT box you can adjust the 2 step to a more usable rpm. You can also set up a nitrous window switch with it, it works as a shift light if you want, and you can adjust the amout of ignition cut if your a quick shifter.
4500 LC is worthless on our car without a serious drag setup. This is adjustable for what you need. I only used the LC portion, the stock WOT shifting works just fine for me.
so for the connector on the driver side the blue cable from the WOT box goes into the solid blue and the green on the solid green/limeish looking one???
and the yellow that goes to the passenger side of the VCM goes into another solid blue cable?
Last edited by cardelino18; Jul 7, 2010 at 12:40 PM. Reason: Automerged Doublepost
http://www.youtube.com/watch?v=whqvIAEhykU
Too bad that's not actually the WOT box since I only had the LC version
