write-up for dejon icp and hks bov
Old Feb 16, 2009 | 09:06 PM
blackrocky's Avatar
does anyone have a full write up on how to install dejon icp and hks bov the right way? also, do i really need an intake?
Old Feb 16, 2009 | 09:21 PM
bootymac's Avatar
i heard you can't use no lift shift after BOV is that true?
Old Feb 16, 2009 | 09:35 PM
blackrocky's Avatar
a few people on here said that it work just fine but you wont hear the bov until you let off the gas
Old Feb 16, 2009 | 10:37 PM
Hawaiian Whore's Avatar
there is no write up necessary... all that you need to do is disconnect cp from turbo, follow it down, and disconnect it from the ic, which is right underneath the car, on the driverside... then pull the whole assembly up... as for install, i did the bottom part that connects to the intercooler first, then worked my way up
as for nls, yes, i can still do it, it does NOT blow off until you let off of the pedal
oh, and w/ hks bov, look at the solenoid that has 3 vac lines attatched... clip the middle one (facing left) put a t valve on it, hook it back up to the solenoid, then run the other to the bov
Last edited by Hawaiian Whore; Feb 16, 2009 at 10:37 PM. Reason: Automerged Doublepost
Old Feb 16, 2009 | 10:45 PM
blackrocky's Avatar
did you use the bov block off plate and did u get a cel?
Old Feb 18, 2009 | 10:41 PM
HB_SS/TC's Avatar
I used a block off plate.
You can see in this pic exactly how I hooked up the bov. No cel's
Old Feb 18, 2009 | 11:42 PM
FutureEcotecOwner's Avatar
I'll give it about halfway thru the night before this thread is locked.
Old Feb 18, 2009 | 11:46 PM
Mazdaboi318's Avatar
why would it be locked?
Old Feb 18, 2009 | 11:47 PM
It seems they're talking about products from a company that isnt a vendor, but I guess since they're not trying to sell their products it's ok.
Old Feb 18, 2009 | 11:57 PM
Magill8's Avatar
there trying to become one currently
Old Feb 19, 2009 | 12:02 AM
I believe they, just like many other respectable people and companies have been trying for awhile.
Old Feb 19, 2009 | 12:36 AM
SRTrent's Avatar
wow... yes no lift shift will still work. like stated before you won't hear it blow off. if you shift fast enough like me you won't hear your **** blow off at all or it will just a little bit without using no lift shift. it's good to have an aftermarket BOV to relieve boost pressure though and for the sound. (:<
Old Mar 9, 2009 | 12:37 PM
BoostedSSCobalt's Avatar
You didn't get an "cels" right? How long have you been running the bov open?
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
breds2k
19
Sep 21, 2015 10:24 AM
