ZFR Turbo Flutter ?
i perfomed the boost leak leak test this morning
and of course its leaking from something i didnt touch
its leaking from the inlet sensor where it mounts to the lower intercooler pipe to the intake manifold
does any one offer a aftermarket gasket for this sensor
only way i can find the gasket is to order the whole sensor
O-RING 3 Bar Map Sensor 12626998
This one's for the GMS1, however I believe they're the same.
When you install the 3 bar sensors, make sure to have the tune on the car modified to rescale for them. Otherwise you will run into problems because the car won't correctly interpret the boost level that the sensors are telling it.
sorry sunburst not trying to totally hijack your thread but Ive noticed a couple of times since my ZZP tune that when I do a half throttle pull in 2nd I'll get some flutter after I left off the gas..I have full bolt-ons with the stock bpv; am I runnin too much boost or is this pretty normal on the k04?
