zzp 256 kit
S256 on zzp's site is $730
Used Intercooler $250
Used hotside piping with BOV $300
Used Manifold $200
Used wastegate $150-200
So, sorry, $1680 roughly. That's also assuming that you are able to find good deals on all of those items. No need to buy new on everything but if you did buy new it would still be less than $2k for a solid 425-450whp car
Edit: And all of those prices are prices that I've seen listed on this site for the used items.
Used Manifold $200
I think ZZPs mani is only $300 though correct?
thats pretty much how every turbo kit works on these cars so far. by the time its said and done your better off just buying the companies downpipe and calling it a day. it will make life easier for you.
Hmm that's impressive but going over the 450 mark on stock internals besides valve springs scares me..
I think the s256et is the perfect turbo. With a .55 AR it spools practically like the s252 and u can make 410sae reliably. If u want to get freaky, up the boost to the low 30s with e85 and get 550whp with incredibly quick spool.
yeah dump tubes arent expensive.....realistically you should know what your doing and what you will need. if you dont have a clue by the kit. piecing one together is for someone who knows what they do and dont need.
i know whats needed for a turbo kit, i just don't know if i want to run a open dump or recirculating
i was gonna buy that manifold from monograt but by the time i got him to check the flange someone already sent him cash
but its really down to the 28 vs 256, but then i'm just thinking of going full custom and getting a gtx 30
Lol @ those who think the bnr is equal to the s256et. Clearly u need an education. Zzp got 425whp sae on the bnr @ 25psi with ethanol and stated that the turbo was pretty close to max. They got 411 sae on pump gas from the s256et at the same boost level as the bnr. 25psi is just getting started for the s256et. Scythe_Snake put almost 600whp down on a stock motor with the s256et.
