zzp 256 kit
Old Mar 25, 2012 | 06:49 PM
  #51
Cobe's Avatar
How much more is the stage 3 s256et then the stage 3 s252et?
Old Mar 25, 2012 | 10:11 PM
  #52
Matt M's Avatar
The bnr can support somewhere around 430-440whp on Ethanol. The 256 ET can support 550+.
Old Mar 25, 2012 | 10:14 PM
  #53
05Slowline's Avatar
Originally Posted by JacBlackSS/TC
i know whats needed for a turbo kit, i just don't know if i want to run a open dump or recirculating
i was gonna buy that manifold from monograt but by the time i got him to check the flange someone already sent him cash
but its really down to the 28 vs 256, but then i'm just thinking of going full custom and getting a gtx 30
open dump ftmfw
Old Mar 25, 2012 | 11:39 PM
  #54
CMVsst2010's Avatar
It's a hundred dollar difference. That's the main reason I got it. A hundred bucks more for a turbo that can withstand over 500whp no problem. I'm loving this turbo. Daily driving has been great.
Old Mar 26, 2012 | 09:08 AM
  #55
Cobe's Avatar
I think the 256 is the winner then haha now you guys keep talking about the ar. 55.? was or is their a difference? Where do you choose what size you want?
Old Mar 27, 2012 | 08:35 AM
  #56
FasterIsBetter's Avatar
You'd probably want .55 a/r exhaust size since its best for spool up. Any bigger exhaust a/r size means a slower spool up but better exhaust flow so therefore better peaks numbers but whats peak numbers when you can't even use that power due to having to rev the engine higher to spool the compressor up to the same speed as you would with the smaller exhaust size.
Old Mar 27, 2012 | 09:18 AM
  #57
Cobe's Avatar
Does zzp let you choose your a/r size?
Old Mar 27, 2012 | 09:29 AM
  #58
It comes with .55 a/r and I'm sure you could email a customer service rep and have them change your exhaust a/r as they don't make it readily available because it would be more realistic to get an S259-S262.
Old Mar 27, 2012 | 03:04 PM
  #59
raver0789's Avatar
After I ordered my kit I saw that the s259 also comes in the .55AR variety. I was pissed at myself lol.
Old Mar 27, 2012 | 07:48 PM
  #60
blrt's Avatar
Why would you buy a s259 if your goal is 400whp?
Old Mar 27, 2012 | 07:53 PM
  #61
Dart_SI's Avatar
s259 is getting pretty big for a cobalt.
Old Mar 27, 2012 | 09:23 PM
  #62
raver0789's Avatar
Actually my goal is 400 for street, and to have 600 for track on full e85
The less boost it takes to get to 600 the better.
http://www.youtube.com/watch?v=rh7PzU6qrsM
u can see lag isn't that bad considering the size of the turbo. full boost by 4k.
Old Mar 27, 2012 | 09:59 PM
  #63
blrt's Avatar
I was just messing with you..
Very true. The less boost, the better. You are going have to invest in a lot of tires???
Old Mar 28, 2012 | 11:38 AM
  #64
hucks1987's Avatar
What this this extended tip do. Or for
Old Mar 28, 2012 | 12:18 PM
  #65
yellowss7590's Avatar
Betta flow and more powaaaaa
Old Mar 29, 2012 | 09:05 AM
  #66
hucks1987's Avatar
Will our stock o2 housing would with the 256?
Old Mar 29, 2012 | 09:17 AM
  #67
Dart_SI's Avatar
You will need a custom dp.
Old Mar 29, 2012 | 02:47 PM
  #68
hucks1987's Avatar
The $400 one from zzp
Old Mar 29, 2012 | 08:39 PM
  #69
Yeah, just need to make sure its a v-band outlet on the turbo. Or just get a 5 bolt to v-band adapter.
Old Mar 29, 2012 | 08:42 PM
  #70
And THAT is why I have your s256et kit, lol!
Old Mar 30, 2012 | 01:29 AM
  #71
CMVsst2010's Avatar
Couldnt agree more! lol
Old Mar 30, 2012 | 09:39 AM
  #72
blrt's Avatar
I think the ZZP S256 may just be the aftermarket turbo of choice? It's gaining popularity. We should start a list of who has what aftermarket turbos?
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
