zzp bov?
Old Apr 25, 2011 | 09:27 PM
turbo_chevy_cobalt's Avatar
zzp bov?
Just installed the bov and it not opening at low boost. I have it hooked up strait to intake manifold. Does the vac tank need to be installed back on?
Old Apr 25, 2011 | 09:38 PM
iboost's Avatar
pics?
Old Apr 25, 2011 | 09:43 PM
Supercharged Guy's Avatar
I had the same problem when I had it too..
I think mine was install error of my part but it was pissing me off so I just got rid of it
Old Apr 25, 2011 | 09:44 PM
BPacak's Avatar
Vtec Rep
something doesnt sound right here haha
Old Apr 25, 2011 | 09:48 PM
Originally Posted by iboost
pics?
It one line from bov to nipple on intake manifold. Lol
Old Apr 25, 2011 | 09:52 PM
iboost's Avatar
what happend to your little black box in the intake mani?
Old Apr 25, 2011 | 09:58 PM
05Slowline's Avatar
lol i tried to put the air fitting on and the part in the middle started to screw down into the bov...opened it up and loctited that piece but idk if i trust it now
Old Apr 25, 2011 | 10:01 PM
Originally Posted by HHRSSouth
Is ZZP's adjustable spring tension?
You could always try the solenoid method and see if it works.
It doesn't look like it is. And tried that didn't work. I don't have the vacuum tank to try that.
Old Apr 25, 2011 | 10:16 PM
Niether do I, vacuum tank bypass here. The vacuum tank bypass actually makes the bov react faster through the solenoid without the vacuum tank hooked up
Just run the manifold vacuum to the solenoid nipple pointing to the front of your car on the wastegate solenoid. (that went to vacuum tank)
Then use the wastegate solenoid vacuum line that point towards the passenger side that went to your stock BPV and hook it up to your BOV.
Try that out and see if you can get the bov to vent, you can set your bov spring pressure super light also as the wastegate solenoid will keep the BOV shut at idle.
If it won't blow off with the BOV set to light spring pressure, I would get ahold of ZZP and find out whats up.
Tried that didn't work.
Old Apr 25, 2011 | 10:17 PM
09CobaltSS1's Avatar
That would be the wastegate solenoid
My Tial Q BOV works off that with a 6 psi spring, stays shut at idle and blows of and reacts quick as hell
The wastegate solenoid is located on the turbo itself, not on the intake manifold. The "black box on the intake mani" is the BPV solenoid..
Old Apr 25, 2011 | 10:36 PM
HHRSSouth's Avatar
You feel better now?
Yes the one on the manifold is called the BPV solenoid not wastegate solenoid, sorry to all the people I confused when I referred to the "black box on the intake manifold" or "solenoid on the intake" as a wastegate solenoid. /wrist
Old Apr 25, 2011 | 11:26 PM
chrisjaldin's Avatar
bump for a short video on how it sounds.
Old Apr 25, 2011 | 11:40 PM
I would but don't want to hurt the turbo.
Old Apr 26, 2011 | 06:33 AM
wow.. settle down there little fella. I didn't mean to insult your delicate ego by simply clearing up the correct name of what something is actually called when that is what you were doing to iboost when he refered to it as "the black box on the intake mani" in the first place. I hadn't realized you were such a delicate little flower..
Oh and yes.. NOW I feel better..
Old Apr 26, 2011 | 08:14 AM
HHRSSouth's Avatar
That was settled down , I edited my post about 3 times before that.
I actually thought that was pretty civilized compared to what I edited the 3 times before. I gave you the benefit of the doubt
Old Apr 26, 2011 | 08:20 AM
firerat's Avatar
Why would you install a BOV? There is no performance gain to be realized by installing an aftermarket BOV...
Old Apr 26, 2011 | 08:23 AM
HHRSSouth's Avatar
He has a BNR 2871, the same as I do. You have to install a BOV
Old Apr 26, 2011 | 08:24 AM
BartSS's Avatar
Its for the ricer within. I got one too lol.
If you want that bitch to work right get tuned for it. But yeah something doesnt sound right here. I cant see pics if there were any posted since im at work
saw this after i posted
Old Apr 26, 2011 | 08:55 AM
haha.. nice! Now I'm kinda curious to be honest..
Old Apr 26, 2011 | 10:21 AM
I have had a bov on the car for 2 years now and that bov was leakingso I went with a better one.
Old Apr 26, 2011 | 12:15 PM
efactor's Avatar
for $60 you bet I would go to a better bov like Tial
Old Apr 26, 2011 | 12:29 PM
Tial might be great but this is my dd and don't want high dollar parts on it. Then I more of a target to have the car stolen.
Old Apr 27, 2011 | 11:31 PM
RyRidesMotox's Avatar
Ok so the vacuum line from the stock bpv should connect to the nipple on the BOV. Is your MAF before or after the BOV? I had better luck relocating the MAF to the cold side pipe just before the throttle body.
OP... Post up pictures of the Vacuum solenoid on the manifold to show us your routing of the vacuum lines... I'm sorry but one sentence in the original post does not clarify what is going on enough a video might help as well.
It is normal for the BOV to surge a little below... say 5psi depending on your setup. It won't open at all if you are simply revving it in neutral or with the clutch in, the wastegate vents around the turbo so you experience minimal engine loads if I recall correctly.
Old Apr 27, 2011 | 11:42 PM
05Slowline's Avatar
who steals cobalts lmfao
Old Apr 27, 2011 | 11:52 PM
Other cobalt owners... for parts
EDIT: interior parts... oh and new transmissions
