ZZP upgraded LNF fuel injectors?
The dope. Figured it be on here today this is going on my list hopfully its ready by winter when I plan on getting all my goodies. This totally makes me happy I went from sc to tc now!!
Idk who said these were from the ZL1... the ZL1's LSA powerplant is not DI
Next, my guess is these should work on all of the 2.0L DI engines because to date there are no other size of DI injectors in the GM lineup, and if I remember correctly the 3.6L DI engine commonly found in the Camaro also runs the exact same injectors (they just have 2 more).
#36
#37
Like others side I'm sure cams w the lobe would def complement these injectors. Sub'd for results tho. I must see good data and results to consider a yay or nay for me.
#43
has anyone read the ZZP FB page on this..
the fuel lobe and injector are the part of the problem, there is another issue that needs to be address too.. the HPFP & Injection timing window in the tune..
#45
Maybe the injector pic is just a teaser to throw us off the real deal....they said 'fueling' in their post. Maybe they are working on the pump itself
Injectors would be cool but they arent THAT maxed out for the average joe just yet, the DI pump is what ALL of us need and then injectors next for the BIG power guys.
#50
The thing is the 5th injector is kinda like meth, it works, and I have one, but its a bandaid. Fix it with the right parts. The other thing is how many lsj's are pushing that kinda power? Not many, there are more stock turbo lnfs pushing more power then most turbo swapped lsj's. like stated above we don't know of there bringing out injectors, it might be a fuel pump. If your a conventional big turbo you don't need a fuel pump tho, the efr is where that will help do to the hard low end hit
