ZZP's Complete LDK Engine in a 2007
Old Apr 11, 2014 | 03:26 PM
roanicon's Avatar
Hey everyone, I was looking around at new engines and I came across ZZP's LDK engine, which is the European equivalent to the LNF. Would it be able to fit in a 2007 cobalt ss, and what would be some possible issues I would come across.
Heres the link;
GM ACDelco - Complete LDK Engine #
Old Apr 11, 2014 | 03:30 PM
Shortbus's Avatar
This Is what you are looking for if you own an lsj and want a new motor.
ZZPerformance - Gen 3 LSJ Short Block #ZZ-LSJSB
Old Apr 11, 2014 | 03:32 PM
roanicon's Avatar
I'm trying to avoid buying the block because then I would have to purchase new heads, valves, cams, valve springs, timing chain, head gaskets, etc. I would prefer a whole new pre-assembled setup. So, with the LDK engine, would it be possible?
Old Apr 11, 2014 | 03:37 PM
user 72239's Avatar
Negative. its DI and meant for an LNF PCM. You would need to swap in the LNF PCM+Wiring harness which means wiring the entire car.
jmdubose202
Dec 29, 2015 05:06 PM
deviance
Nov 24, 2015 05:51 PM
soundjunky
Sep 3, 2015 01:18 PM
Macgyver2484
Sep 2, 2015 05:44 PM
