$310 to change a thermostat? wtf
My dealer wants $310 to change my thermostat. I think that's insane.
My cobalt is coming upto temperature if I let it Idle for a bit, but as soon as I get upto speed it's dropping to around 110deg running temp. I can't imagine paying $310 for a $15 part change, but I cant even find the stinking thermostat. Where'd GM put it?
Do I need to take anything out to get to it?
Why didn't they just put it on the head like every other car made for the last 100 years?
yup get swivel extension 6in and take the bolts out you dont need to drain the cooling system you will only loode about a quart and do not remove the pressure cap on the coolant tank and make sure its cold when you do it
Think thats bad look where they put it for the Envoy with the I6.
Light Truck GMC 2005*ENVOY SLT 4WD*COOLING SYSTEM-GRILLE-OIL SYSTEM*2002-2008 ST RADIATOR HOSES (LL8/4.2S)* Car parts for your Buick, Cadillac, Chevrolet, Hummer, Light Truck, Oldsmobile, Pontiac, and more!
Book says to remove the alternator in order to change the thermostat. You can do it from the wheel well without taking out the alternator with about 2 ft of extensions but its a bitch. They are nice enough to combine the housing and thermostat into one unit so it costs you $50 for the theremostat instead of $15
By the way if you are ever lookking for illustrations of how things go together on our cars Compnine rocks.
http://www.compnine.com/
Ehh... considering the location of it on the Eco, that's not entirely unreasonable. Sure it's cheap little part.. but it's tucked under the exhaust manifold, between the engine & firewall. Takes a lil bit of labor to change one out.
I thought I found it until i saw your picture. Is that it on the left side of that horizontal pipe, which would be behind/under the exhaust manifold (which you have off in the picture)?
You can pull the fusebox out to make it easier to get access to. I did mine last night.. took about an hour doing it that way.
Thanks for all your input gentlemen. I'm gonna drive my truck until I have time to wrench on the balt. I WILL do my best to take pictures and document my work for everyone else having to change their thermostat.
