*boostinss*'s build
Old Jan 19, 2010 | 05:23 PM
*boostinss*'s Avatar
*boostinss*'s build
Ok Guy's ive been waiting for this for a long time and my last piece i need will be here tomorrow. Right now im running on a stock pulley, injectors, and Tune. all i have now as for performance would be a custom cat back CA v2 header and a K&N CAI. I have a GM Stage 3 PCM, Smoothflow Modular Pulley System 2.9, 42# Injectors, Stage 2 belt, Option B Tank, ZZP Intake manifold spacer, NGK 1 Step colder plugs, And i will be doin a custom dual pass end plate. I will get lots of pics. Im starting the tear down tonight. Wish me Luck
Old Jan 19, 2010 | 05:33 PM
ei3dag3's Avatar
goodluck man, take your time and do it right.
dont forget the bolt in the back of the mainfold
Old Jan 19, 2010 | 06:49 PM
Supercharged Guy's Avatar
Dont mess anything up lol I'm sure you'll be fine good luck man
Old Jan 19, 2010 | 10:53 PM
Ok guys everything went smoothly. Thank God! lol.
Will here the starter before i ripped her apart
http://i779.photobucket.com/albums/y...sCamera019.jpg
Got the Charger off
http://i779.photobucket.com/albums/y...sCamera020.jpg
While i was here i swapped out the stock injectors with the stage 2's
http://i779.photobucket.com/albums/y...sCamera021.jpg
Got the intake manifold off. (yes that back bolt was a pain in the ass had to take the alt. off the get to it)
http://i779.photobucket.com/albums/y...sCamera024.jpg
Swapped the laminovas around for the Custom Dual pass.
http://i779.photobucket.com/albums/y...sCamera026.jpg
Heres the plan for the Dual pass. Bought the Bung and npt fittig off ebay for less then $10. Dropped it off at the Machine shop.
http://i779.photobucket.com/albums/y...sCamera025.jpg
Nows shes waiting for the dual pass to be done to get the manifold back on. More info when i get it back.
http://i779.photobucket.com/albums/y...sCamera027.jpg
Old Jan 19, 2010 | 10:59 PM
BumbleBee's Avatar
nice pics
Old Jan 19, 2010 | 11:01 PM
Originally Posted by BumbleBee
nice pics
Sorry fixed the links
Old Jan 20, 2010 | 12:57 AM
scotch89's Avatar
so how are they going to do the dual pass? just drill a hole then weld the nipple on? i want to do this.....
Old Jan 20, 2010 | 01:26 PM
Yea thats what im doing there drilling a hole where the black circle is. then welding the bung in.
Old Jan 20, 2010 | 01:34 PM
eurochevy's Avatar
lookin good
Old Jan 20, 2010 | 01:45 PM
jonathan923's Avatar
so gm stage 3 pcm means no AC? is this true?
Old Jan 20, 2010 | 03:10 PM
Yes this is true
Old Jan 20, 2010 | 04:07 PM
Originally Posted by *boostinss*
Yes this is true
HOLY...u must have some fresh weather there bro...goodluck with the new setup anyways! let us know bout the gains!
Old Jan 20, 2010 | 05:48 PM
YzRider452's Avatar
How much did the bung cost ya for the custom dual pass? and how much is the machine shop doing it for???
Old Jan 20, 2010 | 06:00 PM
scotch89's Avatar
^^^^^^^i want to know this as well im getting my stage kit and im wanting to save as much money as possible. can u add a link for the bung and the nipple.
Old Jan 20, 2010 | 09:22 PM
Ok guys update. Well when i got home from school i had my package from zzp with my obtion b tank and bracket. Thanks for the fast shipping zzp. Well i went to my work (where im doin the build) to start.
First thing i put the option b and plumed it all as far as i could go at the moment.
http://i779.photobucket.com/albums/y...sCamera006.jpg
After that i went and picked up my end plate. They did a perfict job. Got it all done for free.
http://i779.photobucket.com/albums/y...sCamera007.jpg
http://i779.photobucket.com/albums/y...sCamera008.jpg
Well i installed it on the intake manifold and got ready to install the zzp manifold spacer.
http://i779.photobucket.com/albums/y...sCamera009.jpg
Remember to install the intercooler pump spacers so you can put in the lower intake manifold bolt in.
http://i779.photobucket.com/albums/y...amera010-1.jpg
and the lower one.
http://i779.photobucket.com/albums/y...amera011-1.jpg
I hope this is helpin people who plan to do this in the future.
Tomorrow i should get my supercharger back with the smoothflow hub on. should all be put together tomorrow then friday to the dealer for the security relearn.
Last edited by *boostinss*; Jan 20, 2010 at 09:24 PM. Reason: Automerged Doublepost
Old Jan 20, 2010 | 11:04 PM
scotch89's Avatar
thats pretty cool they did it for free. where did u get the bung and nipple at?
Old Jan 21, 2010 | 12:35 AM
YzRider452's Avatar
He said he got it off ebay.
Old Jan 21, 2010 | 12:39 AM
scotch89's Avatar
i found everything off zzp site
Old Jan 21, 2010 | 12:44 AM
Caligula's Avatar
Random..
Do our cars work without the Supercharger on ?
lol.
Old Jan 21, 2010 | 09:10 AM
nice work man. good luck with everything. keep it up
Old Jan 21, 2010 | 09:20 AM
Illini_06SS's Avatar
Originally Posted by Cobaltssdudee
Random..
lol.
No throttle body + no MAF = it ain't gonna run. (and if it does, I don't wanna be near it...)
Old Jan 21, 2010 | 10:19 AM
JapEatr's Avatar
South Central *********
looking good, please remember to route the IC hoses so they are all downhill of the resivior, otherwise you will kill your pump and have high IATs
Old Jan 21, 2010 | 01:54 PM
What do you mean by run down hill from the resivior? is there anyother tips that i should know? Thanks guys
Can i get some info about this CASE Relearn or Security Relearn? what are these really and how will he car run with these on and will they come on? Thanks
Last edited by *boostinss*; Jan 21, 2010 at 01:54 PM. Reason: Automerged Doublepost
Old Jan 21, 2010 | 02:29 PM
JapEatr's Avatar
there is a procedure to bypass the security relearn, however the CASE relearn must be done with HPtuners/Tech2/some Interceptor models do it as well
the hose from the bottom of resivior should route beneath the upper support and go behind the headlight, thru the grille area, then in front of the manifold. coolant doesnt flow uphill with just gravity of the resivior height
Old Jan 21, 2010 | 09:53 PM
Hey guys i think i have some BIG PROBLEMS. well i got her running. she started up on the first crank. It seems to run good but it runs hotter than it did. 40 degrees and its anywhere from 187-193 degrees. well the boost is the Biggest problem. In second gear i peak 17psi at 6500 rpm. in third i peak 19psi at 6500? whats wrong here? also how do i know if i have to do the case relearn? i have no CEL and my scanner isnt reading anything?
