*boostinss*'s build
ok guys Update. Well i got my crank relearn today and yes that makes a hugh differance in power. i was only seeing 4-5 degrees timeing at WOT. now i see 15-16 degrees advanced. now the last issue i have to deal with is the header and downpipe.. ill let you guys know when i get that in then off to the dyno to get numbers.
Ok i have just tested my high octane mode tonight. and let me say this OMFG!!
Thats where all the hidden power is at. it runs 22-23 advanced timing at full throttle. i wheel hopped in to thrid gear
i guess i need mounts now after the header.
Thats where all the hidden power is at. it runs 22-23 advanced timing at full throttle. i wheel hopped in to thrid gearok guys Update. Well i got my crank relearn today and yes that makes a hugh differance in power. i was only seeing 4-5 degrees timeing at WOT. now i see 15-16 degrees advanced. now the last issue i have to deal with is the header and downpipe.. ill let you guys know when i get that in then off to the dyno to get numbers.
Yes the relearn DOES MAKE A DIFFERANCE!! when i had the code i was only running maybe 6 degrees advanced timing and after i was hitting 15-16 degrees and its alot snapier. you get it done at your local gm dealer and it only cost me $54. Hope it helps.
UPDATE.... well tonight i installed my new header. YES I GOT A JBP HEADER. Thanks LS1fbody.. love the new sound with the dual slp loud mouths its nasty. plus i gained some nice top end and dont notice any leaks. now a clutch light pound flywheel then dyno.
Oh and i pick up a set of Bwoody tractions bars for 70 buxs. Thanks again NOS2006.
