.035 plug gap stock?!
Okay so I put on the 2.9 pulley today for the stage 2 and from what I read you should start out with .040 gap for the 2.9's. I pulled the plugs out thinking I was going to have to reduce the plug gap and to my surprise they were .035! I read on a thread that the manual states the stock plug gap to be .042..could the smaller .035 stock plug gap been my problem with the sudden lurching motions I would get at high RPMs sometimes? I went ahead and gapped them at .040 and it feels great and love the extra kick it gives me!
How cold was it when you got the 16 PSI?
it was about 65 when I took it out to test it this evening...
Last edited by XCRuna1201; Apr 30, 2008 at 12:14 AM. Reason: Automerged Doublepost
Littlegoose, where did you dyno those numbers at in your sig? GSC, AV Engineering, or PowerZone? Just curious because there is no way that was at the Show Zone.
My car only like the .035 plug gap. Not sure if it's my mods or what, but anymore more and I get knock. I might need to get another step colder plug in the future, but as of right now the .035 does the trick wiht my BKR7E's
I the 16 seems a bit higher than most it is because we in Charleston are at or below sea level in most places.
Not sure on the recommendaton, but I feel that if you are seeing knock at that point it might be time to make the step down. I'm pretty much borderline and could probably use to step down, but the car was running awesome right before I deployed, so we'll see what's up when I get back.
I figured your numbers had to be on a Dynojet because the Show Zone's Mustang Dyno is a true heartbreaker. My setup in my sig before the meth only put down 238whp and 230wtrq on their dyno, yet my car is a lot faster than the numbers show. As another example my GM S2 w/2.8" & I/H/E laid down 214whp and so didn't my buddies with the same setup, so I know it's consistant, it just rates a lot lower than the local Dynojets do. Just be prepared to see a lot lower numbers than you're used to if you start dynoing there.
If your car is running better with the .040, then go for it! A lot of people on here run that gap with their cars and it works out great. My car is just retarded and fights me every step of the way!
Yeah it is running great but when I started it up after the install and came back from the test drive I could have sworn that a clicking noise that I was hearing in the engine bay was not there before....could that be knock a clicking noise? As i said I cant remeber if it was there before or not but I know the supercharger does have some odd noises...?
oh okay well its defiantly not that its just a little clicking noise....my friends dad showed us a cool technique on how to listen to the motor. Have you ever used a STICK to listen to it?
lol im not kidding who wants to know how to do it? I mean come on who doesnt want to listen to the INSIDE of your supercharger?
Yeah, GSC recommended I go to AV-Engineered. I'm half tempted to go to them since they use the same dyno that gsc did (except theirs has load correction, GSC's did not) and that would give a slightly more accurate result (of my last dyno, to one with my current mods) than going from dynojet to heart-break mustang haha. What do you think? Should I use AV or just bite the bullet, go to showzone and use that as my new baseline with my current mods?
