06g85blackss/pauls new turbo toys :)
Old 03-12-2008, 10:43 AM
  #126
Rent me! per hour
Area47's Avatar
Originally Posted by 06blackg85ss
ok problem was spike said, no provision for the stock PCV hole, just drilled and tapped the oil fill cap, ran a -8 an elbow, piece of line, to a 1" k&n breather, and all is good.
Now it's running dumb rich, need to figure that out, but I think it's just from the oil going through the exhaust, fucked up the O2 sensor.
fuel pump I'm going with will probably be a Bosch 044, dual return rails, Y fitting, and dual port regulator. Should do the trick. Hopefully I can find something to drive for next week cause the shop can take the car in on sunday
run a bigger line.
stop waiting for aem. you will be waiting till july for the dbw stuff.
convert the tb and pedal to cable drive and be done with it.
Old 03-12-2008, 01:13 PM
  #127
StreetDreamz's Avatar
So you will be using an inline pump? Setup as a returnless system? How do you intend to get the fuel back into the tank?
Old 03-12-2008, 01:16 PM
  #128
Rent me! per hour
Area47's Avatar
he is hiring midgets to sit under the hood and dump fuel.
Old 03-12-2008, 01:18 PM
  #129
lsjwannabe's Avatar
i like the idea, how many gph?
Old 03-12-2008, 01:21 PM
  #130
Rent me! per hour
Area47's Avatar
depends if they are meth injected or not
Old 03-12-2008, 01:22 PM
  #131
R&C_rallySS's Avatar
Badass, I love what people do to cobalts.
Old 03-12-2008, 01:24 PM
  #132
Raven SS's Avatar
hmmm..
Old 03-12-2008, 01:32 PM
  #133
memphisr24's Avatar
Midgets ftw
Old 03-29-2008, 06:42 PM
  #134
spike's Avatar
paul u said u had 2 mod ur oil cap 2 run the hahn intake mani........... found this............
http://www.exoticperformanceplus.com....html?item=756
this should make it easy for those like myself going with the hahn intake mani as well
Old 03-29-2008, 06:45 PM
  #135
06blackg85ss's Avatar
nice man, I sorta rigged up the same thing
Old 03-29-2008, 07:50 PM
  #136
Coblt ss super's Avatar
DAM PAUL!! you beat out 400 hp
Old 03-29-2008, 07:53 PM
  #137
it was tough on the ol cobalt... but she made it through
Old 03-29-2008, 08:09 PM
  #138
jimbos'ss's Avatar
holy shiiit congrats man!!!! the first one to break 400whp, so it really does drop off after 6k.
Old 03-29-2008, 08:13 PM
  #139
yeah, but mostly because I no fuel lol.... fuel system is being redone next week btw
Old 03-29-2008, 08:21 PM
  #140
jimbos'ss's Avatar
easy fix, thats awesome, i just sold my supercharger setup so i could afford a fuel setup, i think i will go the route witt did, seems the easiest and most effective. pretty expensive though.
Old 03-29-2008, 09:27 PM
  #141
elecblue06's Avatar
holy **** dude.. thats aweosme what psi was the 411 dyno on? and whats with the dip right around 5 K? is it a tuning issue? or fuel issue congrats man
Old 03-29-2008, 09:32 PM
  #142
RedlineBrian's Avatar
Clutch slip...
Old 03-29-2008, 09:51 PM
  #143
elecblue06's Avatar
Originally Posted by RedlineBrian
Clutch slip...
haha ohhh yea.. i forgot about the sttock clutch issue lol
Old 03-29-2008, 09:53 PM
  #144
BlackSS/SC's Avatar
Awsome numbers Paul! What's your EGTs at? How much timing you running?
Old 03-29-2008, 09:55 PM
  #145
no egt gauge in the car at the moment, really need to get that in lol.
timing started at 26 down low and tapered to 18.5 up top
Old 03-30-2008, 02:56 AM
  #146
Rent me! per hour
Area47's Avatar
you should have warned me on the phone that the dyno graph looked like that
Old 03-30-2008, 03:10 AM
  #147
jimbos'ss's Avatar
$10 cheaper here.
http://www.pfyc.com/pc/GN3020/GNUNDE...er+Filter.html
correction: math>me..........$2 cheaper
Old 03-30-2008, 08:32 AM
  #148
well what you think a 17.22:1 lean spike looks like on paper.... I almost **** myself when I ws watching the laptop
Old 03-30-2008, 12:24 PM
  #149
spike's Avatar
Originally Posted by jimbos'ss
$10 cheaper here.
oh snap......... thanx........
Old 03-30-2008, 12:37 PM
  #150
Smarty Art's Avatar
Man you would defiantly have a better curve with some cams.
Quick Reply: 06g85blackss/pauls new turbo toys :)
