1/4 time
Old Jan 22, 2011 | 04:57 AM
Erick161's Avatar
Originally Posted by Jeffs 06SS 2.4
OH, ok, Sorry man. Sometimes it takes me a while. I thought I was missing a driver mod or something.
Thats ok. Im actually a little offended you thought i was stupid enough to advise double clutching our cars while dragging them
Originally Posted by 1LowLS
ya your lucky that 100 shot of NOS didnt blow the welds on the intake.Now me and the mad scientist have to rip apart the block and replace the piston rings you just fried.
Old Jan 22, 2011 | 05:05 AM
Jeffs 06SS 2.4's Avatar
Well, I was stupid enough to think you meant it. Although, I didnt see the smiley face until later.
Old Jan 22, 2011 | 10:49 AM
Josuizzle16's Avatar
Originally Posted by Perfect.disguise
Open the filler tube in front of the SC and look for air bubbles or coolant flowing while the engine is running. If you see nothing you can tap it( the pump) with a hammer and it can free the brushes up but it is usually a short term fix. A jammed IC pump will heat soak and pull timing.
Alright so I did what you said and I can see the coolant but nothing is happening.! Should I get a new pump or how should I go about this.?
Old Jan 22, 2011 | 11:20 AM
Stone629's Avatar
Lightly tap on the IC Pump with a hammer. It should start pumping again until you can replace it.
Old Jan 22, 2011 | 01:02 PM
Alright I did that and it worked awesome thats crazy how that works lol well I was thinking of getting an aftermarket IC Pump any ideas?
Old Jan 22, 2011 | 01:08 PM
ULWizSS's Avatar
Best pump is the Bosch believe you can get it at zzp and ottp for around 100.
Old Jan 22, 2011 | 01:14 PM
What kind is the stock one??
Old Jan 22, 2011 | 01:29 PM
Perfect.disguise's Avatar
Same as the 03-04 Cobra's.
Old Jan 22, 2011 | 03:02 PM
1LowLS's Avatar
There all Bosch.Even the cobra c230 and lightnings use the same one.You can put a meziere pump but it cost more and is pointless.
Old Jan 22, 2011 | 03:07 PM
Do_WorkSS's Avatar
A little before the redline every time I shifted it barely tapped the redline
thats the problem. when you take your car to redline....power only falls off after certain rpms. learn where your power begins to fall off once you begin to reach the top, and shift at that point
Old Jan 22, 2011 | 03:21 PM
  #36
Stone629's Avatar
His car should be making power upwards of 6500 rpm. I don't think shift points are his problem. His IC pump was obviously taking a snooze. That alone can cause significant power loss once the PCM starts pulling timing.
Other than that, you can't expect anyone to run the car at full capability on their first trip to the track, or 3rd, or 5th, lol.
Old Jan 22, 2011 | 03:59 PM
  #37
Yeah, stock rev limiter is 6.5K..no need to shift any sooner.
Old Jan 22, 2011 | 05:23 PM
  #38
Do_WorkSS's Avatar
yes, and i understand that....however, you cant deny that you do experience power loss once you get too high into rpms.
Old Jan 22, 2011 | 05:31 PM
  #39
Stone629's Avatar
Na man, I can deny it. I'm looking at my dyno sheet right now, and its still making power at 6500 where the tuner shut it down.
This is my dyno run before the header, intake, etc.
http://carphotos.cardomain.com/ride_...0104_large.jpg
Old Jan 22, 2011 | 06:52 PM
  #40
Tundraboarder666's Avatar
Still waiting for reply of what car you have. Silver 2006 SS/SC?
Old Jan 22, 2011 | 07:19 PM
  #41
I do.
Old Jan 22, 2011 | 07:21 PM
  #42
07 SS Maroon.
Old Jan 22, 2011 | 07:30 PM
  #43
Oh damn... haha that's good for you at least!
You should come to the Pavs tonight!
Old Jan 22, 2011 | 07:48 PM
  #44
BlackBeast!'s Avatar
07 SS Maroon.
what side of phoenix you live on? join the AZ bs thread!
Old Jan 22, 2011 | 07:50 PM
  #45
you goin to the Pavs tonight EJ?
Old Jan 22, 2011 | 08:09 PM
  #46
yes i am
Old Jan 22, 2011 | 09:29 PM
  #47
He said he was stock...he is fine shifting at redline...
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
