1/4mi for gm stage 3
if you want stage 3 its best you build your own "stage 3".
-dual pass end plate
-2.9 or smaller pulley
-gm stage 2 belt
-injectors, 42lb or 60lb for smaller than 2.9
-hp tuners
-cobra heat exchanger
-gm stage 2 belt
-hp tuners
yeah, stage 3 itself probably isn't going to produce anything better in the 1/4 mile, it does come with a slightly smaller pulley, but its only supposed to be a 10 hp increase. The real reason a stage 3 would be bought is if you're looking to take advantage of high octane without having to tune and also using nitrous which definitely puts you up to the 300hp mark and low 13's.
The A/C delete ... I never use my a/c. If you bought a "sports car" for A/C then you might as well buy a Malibu.
ummm....no you would have to buy all that......and the pcm will let you rev to 8k not 8.5k.........which without the new valve springs is just stupid......
my bad i thought it would be smart for gm to sell a car that didnt fall apart ha ha ah but thats wishfull thinking
