10.0:1 with htv1320??
Old Sep 15, 2008 | 12:42 AM
SuperSport4's Avatar
I am planning on purchasing the htv1320 blower ugrade... i was wondering if any1 has done it with the diamond 10:1 pistons??? and do u guys think it will be safe???
Old Sep 15, 2008 | 12:47 PM
SilverSurferSS/SC's Avatar
I have been wondering about this too.
Old Sep 15, 2008 | 12:52 PM
shabodah's Avatar
This is part of my build plans, but normal gasoline is not.
Old Sep 15, 2008 | 12:59 PM
Joeyeljefe's Avatar
what shape pistons are they... im guessing wedged since were raising the compression cuz if they are going to raise your compression you might want to consider machining your combustion chamber and maybe doing a valve job.. and maybe new cams and lifters then youll be fine but your going to have to have a pretty stout exhaust system to handle this
Old Sep 15, 2008 | 01:07 PM
Area47's Avatar
Rent me! per hour
there is someone on here running them with that blower. you'll be fine.
Old Sep 15, 2008 | 01:08 PM
EXsoccer1921's Avatar
yeah i'ld say 9.5:1 or 10:1, with f/i you don't want to go too high in compression. but you still want a good amount.
Old Sep 15, 2008 | 01:11 PM
What would you speculate to be the smallest pulley you could run with 10.0:1 compression?
Old Sep 15, 2008 | 01:13 PM
Area47's Avatar
Rent me! per hour
depends on how well your aftercooler system works.
Old Sep 15, 2008 | 01:18 PM
I see your point. would most likely be on a per car basis too most likely. And a bunch of other factors I'm sure.
Old Sep 15, 2008 | 01:22 PM
lsjwannabe's Avatar
3.1" no lower with a higher compression. You will run into heat issue's and the person running the 10:1 is also running cams so its more like a stock compression.
Old Sep 15, 2008 | 01:25 PM
Area47's Avatar
Rent me! per hour
meh, details.
Old Sep 15, 2008 | 01:35 PM
elecblue06's Avatar
witt on here has that setup if i remember correctly as well as cams and alot of shiot so it'll work (long as i'm right about his setup)
Old Sep 15, 2008 | 01:42 PM
Acidangel_5.0's Avatar
i hear future *pop* followed by thread *blew my motor*
boost = you want low compression
nitrous = you want high
Last edited by Acidangel_5.0; Sep 15, 2008 at 01:42 PM. Reason: Automerged Doublepost
Old Sep 15, 2008 | 02:19 PM
2K5SS/SC?'s Avatar
I would personally stick with 9.5:1 with the TVS if you are thinking of cramming some serious boost in there.
Old Sep 15, 2008 | 03:04 PM
i would drop to 8s if your gonna throw ove 25#
Old Sep 15, 2008 | 03:06 PM
WSFrazier's Avatar
Not worth it for a blower. Boost /= power.
Old Sep 15, 2008 | 03:11 PM
no.. but a man that wants 10:1 with a twinscrew is saying.. HEY I WANT POWER..
ill take .5 off compression and save myself a few HP and have much more realibility on the motor... if for a blower..
but i see turbo discussion coming soon.
Old Sep 15, 2008 | 03:53 PM
Area47's Avatar
Rent me! per hour
newp. if i were to build a drag motor, it would be over 10.0:1 c/r on methonal and 50psi from a giant turbo
Old Sep 15, 2008 | 03:58 PM
WSFrazier's Avatar
+1 I had 10:1, stock cams, 2.5 pulley, no cooling mods. Ran awesome.
Not saying I was pushing that much airflow, just meant my car was worse case scenario for an LSJ as far as heat, and it was fine.
Old Sep 15, 2008 | 04:17 PM
Area47's Avatar
Rent me! per hour
i just find it funny people think lower compression is better for power.
Old Sep 15, 2008 | 04:18 PM
WSFrazier's Avatar
Making the motor less efficient is not my idea of making power.
Old Sep 15, 2008 | 04:31 PM
Area47's Avatar
Rent me! per hour
sssshhhhhh, don't tell them that
Old Sep 15, 2008 | 05:01 PM
Try2k's Avatar
So the consensus is... stay at 9.5:1?
Old Sep 15, 2008 | 05:54 PM
Rodimus_Prime's Avatar
im running the 75mm with the harrop on a stock engine its hot but thats something that can be fixed with better cooling
Old Sep 15, 2008 | 09:16 PM
StevesBlack06's Avatar
lol, love it
