10:1 on high boost
Old Nov 4, 2008 | 08:23 PM
SuperSport4's Avatar
10:1 on high boost
has anyone gone with the diamond forged pistons with 10:1 and high boost or tvs??? wuts the most boost u can go on the 10:1 safely?? can u run the TVS???
Old Nov 4, 2008 | 08:26 PM
ItalianJoe1's Avatar
Its all in the tune man, yes you can. Witt has that setup, with cams and bottle, and his car is perfect.
Old Nov 4, 2008 | 08:29 PM
hows it runnin??? any numbers at track or dyno?
Old Nov 4, 2008 | 08:35 PM
I dunno, he's pretty secretive about it. Try PM'ing him maybe?
Old Nov 4, 2008 | 09:22 PM
brandon2.2's Avatar
GM did it in there build book on CED.com
They used a GM stage 3 pulley
Old Nov 4, 2008 | 09:39 PM
he has pm turned off...... i know they did it.....but i eventually wanna go tvs.... will it be too much boost is my question??? will i get any spark knock can i blow it?
Old Nov 4, 2008 | 09:42 PM
Well, you gotta tune for it either way, so you have to tune it so you don't get knock. I would highly advise meth injection to control it with the TVS anyway. The little bit higher compression isn't going to bother you.
Old Nov 4, 2008 | 09:48 PM
o3nisoaso3's Avatar
yes true but Al's cams dropped the compression a hair and i didnt think he still had the bottle hooked up. He was just at my house last friday and i didnt think it was. The harrop and all that pull hard as hell tho...
Old Nov 4, 2008 | 09:53 PM
Perfect.disguise's Avatar
Well the pistons will be forged.
It will just give you a little more power per lb.
Old Nov 4, 2008 | 10:15 PM
i think thats wut imma do....... should i get them coated or not?
Old Nov 5, 2008 | 09:15 AM
MidnightNB's Avatar
if you run water/meth you'll be able to run higher compression, more boost and more timing safely.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
