119 octane!!! WHAAAT
morons-
" A common misconception is that power output or fuel mileage can be improved by burning higher octane fuel than a particular engine was designed for. The power output of an engine depends in part on the energy density of its fuel, but similar fuels with different octane ratings have similar density. Since switching to a higher octane fuel does not add any more hydrocarbon content or oxygen, the engine cannot produce more power."
do some research, good ole wikipedia can even help out the ill-advised
you are just digging yourself deeper sunshine
just admit you did a dumb thing and move on.
That would cause pre-ignition. You ever heard of knock as people incorrectly call it all the time? That's a bad thing. Running too low of an octane for your setup will cause this. However, the higher the octane of a gasoline (more 8 carbon chains per unit) you use, the more resistance to ignition or the harder it is to burn. More energy is required for a clean burn of each unit of gasoline. This means that if you go higher than the lowest possible octane that doesn't cause detonation/pre-ignition, you are either not burning all of the fuel in each combustion reaction or it is not burning as fast as and consistently as the lower octane gasoline. Obviously you don't believe me, which means you don't know what you're talking about. By the way, my little evo would run you down if i launched in 3rd gear
another one-
"Higher octane fuel has only one beneficial feature - it allows an engine to run at higher temperatures with more advanced ignition timing under higher levels of compression witout detonating / knocking. Higher octane fuel does NOT have more potential energy and will not make an engine perform better unless that engine is knocking. On modern engines with knock sensors, higher octane fuel may make the engine run better if the knock sensors are retarding the ignition timing, which hinders performance. High octane fuel does not burn cleaner, it does not clean your engine, it does not increase horsepower or torque (unless you are experiencing knock), it does not smell better, it does not increase fuel economy (unless you are experiencing knock) and is not better for the environment. If you buy higher octane fuels for any of the above reasons, STOP!"
http://www.superchargersonline.com/content.asp?id=105
come on kiddies, the internet is good for other things than titty pics and instant messaging
#39
#40
No, i wasnt stating you, and i was talking about the information HE gave on his OP.
He said he didnt notice any gains. The second post was someone saying "YOU DDINT FEEL ANY GAINS YOUR STUPID"
#42
you guys fail, and hard. shortstack noone would be calling you stupid or a moron, if you were not speaking like one. facts have been thrown in your face and you still wont listen. thus, you are a moron
#43
[QUOTE=hatrickstu;3188628]morons-
so hold on ur telling me if you tune to a higher octane you will not produce more power? rightttt..
#45
[QUOTE=SS FREAK;3188682]
Not with out turning up the timing.
And learn how to quote SS FREAK(with caps OH NOEZ)
morons-
#46
dear God are you serious? thats not what its saying at all. you are not tuned for that octance level. guess what, i use a different tune at the track. you know why? because i have a more aggressive timing map i am able to use because the higher octane is less likely to knock with that timing map. comprende?
morons-
#47
If you would have read, i didnt do it.
Again, someone not completely reading the sentence..
He said that he just used a little bit of high octane so it wouldnt mess with his spark too much..
Someone though he said he added high octane to increase spark.. which wasnt what he said...
#49
Your car can't turn up spark...only down
