15lbs on 2.8?
Old Aug 21, 2007 | 02:28 PM
cobaltstg2's Avatar
15lbs on 2.8?
ok i have the 2.8 pulley on and i have a full exhaust just wondering if the exhaust lowers the amout of boost you see or i have a problem
when in second gear the car boost really fast till about the 15 and then it kinda feels like it isnt pulling anymore at all.. can there be something causing this like something interal or something else
Old Aug 21, 2007 | 02:30 PM
chevysalesman614's Avatar
i saw less boost after i did my header and downpipe. but hot weather can affect it as well.
Old Aug 21, 2007 | 02:36 PM
Area47's Avatar
Rent me! per hour
im hitting 17.5 with mine. full header, exhaust, blah blah blah.
how hot is it there?
Old Aug 21, 2007 | 02:38 PM
Super_SS's Avatar
im seein 17.5 with my 2.9" and stock exhaust...i was seein 10psi at one time,but the gauge was fucked up...how does ur boost climb?does it go up fast or does it skip numbers
Old Aug 21, 2007 | 02:42 PM
cobaltstg2's Avatar
it goes up fast then kinda stops at 13 then goes on up to 15 during that time if feels like it isnt pulling very hard at all 68 degrees today
Old Aug 21, 2007 | 02:45 PM
Super_SS's Avatar
hmmm..u MIGHT have a broken spring inside the boost gauge....thats wat mine did when it had s2...and all of a sudden it would boost past 10psi...and 2 days later i turn the car off and boost guage is still reading 10psi...had to warrantyed and now it hit 15psi by 4000-5000k and 17.5 by redline
Old Aug 21, 2007 | 02:50 PM
cobaltstg2's Avatar
yeah you think that could be the problem
Old Aug 21, 2007 | 03:23 PM
syP's Avatar
syP
15psi here on a 3.06 pulley... 15 psi on a 2.90 pulley... and 15 psi on a 2.80 pulley..
same problem
Old Aug 21, 2007 | 03:24 PM
Super_SS's Avatar
same problem
go change ur boost gauge...the spring inside the guage gets weak after time and the needle starts to slow down...go to lattof chevy and ask for brian poderaki..tell him Joe sent ya..he will warranty the gauge
Old Aug 21, 2007 | 03:26 PM
syP's Avatar
syP
wtf.. its an autometer gauge.. i never had problems with autometer b4, what gives?
Old Aug 21, 2007 | 03:27 PM
RedlineBrian's Avatar
All i see with my 2.8 is about 16.
Old Aug 21, 2007 | 03:30 PM
Super_SS's Avatar
autometer is one of the cheaper,but good gauges...if u want some accurate gauge go buy a defi..300+ for the gauge and another 200 for the controller...
i remember on my srt when i had the stock gauge,after i installed the big turbo the gauge was acting all weird and **** since the spring inside the gauge went crazy cuz boost was goin faster than the spring can actually keep up,so after time i only saw 12psi on a big turbo..was kinda funny
Old Aug 21, 2007 | 03:33 PM
ggarcia86's Avatar
w/ my 2.8 i get 15psi by 3700rpms, but i have stock exhaust manifold and dp
Old Aug 21, 2007 | 03:34 PM
Super_SS's Avatar
Shot at 2007-08-21
Old Aug 21, 2007 | 04:45 PM
cobaltstg2's Avatar
yeah taht should be about right but do you have a full exhaust like some of the rest of us
Old Aug 21, 2007 | 04:48 PM
1stbluSS's Avatar
header, downpipe, and cat all provide better flow which will mean lower PSI
PSI is just a measure of the compressed air at your manifold, if you have exhaust mods you will have less back pressure there for less psi but more HP
Old Aug 21, 2007 | 04:51 PM
cobaltstg2's Avatar
^^^^thankyou that is the anser i have been waiting for all day... unless my guage is bad
Old Aug 21, 2007 | 04:53 PM
1stbluSS's Avatar
^ your welcome
you actually want to limit your PSI by way of exhausting mods.... more air in = good
more air in and even more air out = excellent
Old Aug 21, 2007 | 05:51 PM
Area47's Avatar
Rent me! per hour
i have full exhaust and seeing 17.5 on a 2.8
hell, i got the stg2 to pull 18 psi. there are many variables. hell i can post a log file if needed, you just have to convert it
Old Aug 22, 2007 | 10:37 AM
cobaltstg2's Avatar
well last nite i took the car out and maxed out 2 gear and same thing it only went to 15 then i maxed out 3rd gear and it went to 17.5lbs of boost ... wtf i dont know what is going on
Old Aug 22, 2007 | 10:42 AM
p7x's Avatar
p7x
are u running 42 lb injectors?
Also I never see FULL boost in 2nd or 3rd close but not FULL.
Old Aug 22, 2007 | 10:56 AM
cobaltstg2's Avatar
yeah i am Y?
Old Aug 22, 2007 | 11:02 AM
p7x's Avatar
p7x
because I never had the boost problem but I did experience that the car kinda gave up problem, it was knock sue to lack of fuel. Im sure your tune is cool but check for knock retard.
Supercharged06SS
Oct 5, 2015 09:13 PM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
Silverbullet333
Sep 22, 2015 10:55 AM
DevZX
Sep 16, 2015 06:19 PM
