2.0 Idle and Lean Problem (STOCK)
Old Mar 19, 2008 | 06:58 PM
Syclone2982's Avatar
I have a 06 SS and the computer thinks it is running lean fuel trim on tech 2 show 32% on long and short term. fuel pressure is about 57psi. Plugs are black(???). idle reves up to about 2300 and then back down until it tries to die and then back up again.
Replace MAF sensor (becuawse I had a P0101 and it hasnt come back)
BAck pressure test is ok
O2 is toggleing between 50mv-950mv(unplugged is is 450mv and runs the same)
cleaned TB 2x
flushed injector2x
PCM is as upto date as it gets
I cant find a vacuum leak for the life of me but the guage will go down to 10hg with RPM and then up to 25hg when it idles up
I cant think of any other test or pieces replaced at this time so ANY help would be greatly appreciated
Old Mar 19, 2008 | 08:02 PM
QuickSilver_SS's Avatar
There is a TSB out for the injectors. I wonder if you may have a bad injector ? Causing it to run lean. Just my 2 cents ??
Old Mar 19, 2008 | 09:56 PM
camarokiller's Avatar
My car is ideling like that and im throwing a p0101 too. I replaced the plugs and they looked fine. Now im going to get a new MAF, i think ithe AEM got wet one to many times. I tried to clean the MAF with electronic parts cleaner, aand it still isnt working.
Can someone confirm that my MAF is bad before I drop 153$ on a new one?
Oh, and my car runs just fine if its at 133 degrees or aboue, anything below trhat and it wont even idle. you have to bounce the revs between 2-3k
Last edited by camarokiller; Mar 19, 2008 at 09:56 PM. Reason: Automerged Doublepost
Old Mar 19, 2008 | 10:03 PM
Sunburst_SS's Avatar
silly question.....but you did check your air intake/filter....make sure there's nothing blocking the air flow right?
Old Mar 19, 2008 | 10:58 PM
If your asking me, i put on a new filter as well.
Any help is much appriciated
Last edited by camarokiller; Mar 19, 2008 at 10:58 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 08:56 AM
Sergio's Avatar
You said your spark plugs are black so try swapping them out and put in the stock ones.
Old Mar 20, 2008 | 09:03 AM
Misery5567's Avatar
I'll venture a guess as to too much air and not enough fuel:
"42.5 injectors, 2.79 pulley"
Mine started running lean (after 6K rpms though) on 42# and a 2.8 pulley. My plugs were black as the ace of spades too.
60# and a tune fixed it right up all across the board.
Old Mar 20, 2008 | 06:17 PM
Im guessing that my AFR is good because my plugs are nice and choclately brown. I have no wideband.
bumpy
Last edited by camarokiller; Mar 20, 2008 at 06:17 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 10:20 PM
After replaceing MAF I no longer have a code p0101
Only code is a p0171 (feul system bank on lean)
I have check the injector with the tech2 and a fuel pressure guage all test the same. Removed fuel rail and tested injectors of leak down (visible signs of fuel at the tip of the injector with key off)
Air intake has been check double checked and then rechecked I dont believe i have a lean condition i do not think i am burning unmetered air.
I cleaned the both MAPs and small changes but not enuff to matter.
I have read every bulliten on a P0171, p0101, and p0300( i beleive this code is being cause becuse the car get so low on rpm it starts to run rough)
the plugs are not black they are factory the electordes are black indicating a false O2 reading(rich not lean) on mine the car IS loading up on fuel and then revs up to keep it from dieing.
Just wondering if someone has had this and replace TB, MAP(one or the other or both), PCM, O2 whatever
OR if anyone would know of a test I could run on the car, sensors my brain anything would be helpful
And thank to you guys who have already replied I hope my awnsers make sence
Old Mar 20, 2008 | 10:25 PM
well, since you have access to a tech2....do you also have access to tis2web???? Make sure you have the current calibration on your PCM. There have been some updates to address the p0171 code.
Old Mar 20, 2008 | 10:39 PM
Yes I have reprogramed it once and tried reprograming remotly with pass threw and with the new tool (cant think of the name at the moment)
It is as up to date as i can get it(I think)
Old Mar 20, 2008 | 10:58 PM
06blackg85ss's Avatar
sorry man you got me, does sound like a bad injector though, or a decent sized vacuum leak.
Old Mar 21, 2008 | 08:47 AM
Im no car god. But it really sounds like a bad injector as i mentioned earlier on. I could be wrong. But, if you did replace all 4 of them and your problem went away. I wouldn't be surprised ! Just my thoughts !!
Old Mar 21, 2008 | 12:01 PM
this still doesnt explain my problem. after the car is warmed up it runs just fine.
Old Mar 21, 2008 | 04:24 PM
I would say if it runs bad when cold and not when warm check 1/1 O2 sensor
basically I think you need to look at what affects the car in open loop and what chenges happen on closed loop.
Old Mar 21, 2008 | 05:05 PM
I wonder about the coolant temp sensor. I had an old 94 Z24 that did something similair. I wonder if its worth giving that a try ?
Old Mar 22, 2008 | 12:05 PM
This was mo thought too, but my code if for MAF
Old Mar 24, 2008 | 02:02 AM
Old Mar 24, 2008 | 02:05 AM
BlackSSNick's Avatar
I had this exact same problem when I bought my cobalt this past august. I was throwing lean codes out the ass. I bought a K&N Cold air intake and have not thrown one code since. These car should not be running lean stock, they are tuned from factory to run rich because of warranty issues. If you got your stock cars richness tuned out, you would gain probably about 15 - 20 horsepower. I got my car dynoed and it read my car at 10 afr. Thats rich as hell and the stock tune with a K&N CAI. Get a CAI and you won;t throw anymore codes.
P.S. I see you live south of da burg...I'm guessing you mean pittsburgh. I used to live south of the burg as well, in waynesburg, pa. Ever hear of it?
Old Mar 29, 2008 | 03:32 PM
I have an intake, already. Too bad i think i totaled my cobalt last night.
Yes i have heard of waynesburg. I live in Masontown, and i work in Carmichals. Shitty little area, huh? lol
Old Mar 30, 2008 | 01:59 PM
yes it is. I have family that I rarely speak to in carmicheals lol.
Old Mar 30, 2008 | 02:49 PM
I work at a pretty big machine shop down behind soloman dodge.
Old May 25, 2008 | 08:11 PM
Well Here is the update
problem 2 small unhearable and unseable exhaust leaks and the biggest one is what fixed the majority of the problems 1 ant the manifold to pipe fixed this and car ran better but still had lean code and surged the onther leak was all the way at the cat pipe to muffler pipe fixed this and lean code went completely way and car ran great. keep in mind this leak wat 2.5ft away from 1/1 O2 sensor maybe farther.
Just though I would let you know
satisfied
Oct 19, 2015 12:35 AM
camaromanss1992
Oct 1, 2015 10:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Cptnslo
Sep 24, 2015 09:32 AM
ATOMbomb
Sep 11, 2015 10:48 AM
