2.0 lsj g5
Old May 20, 2010 | 06:35 PM
RDKDESIGNSG5's Avatar
2.0 lsj g5
I have a G5 GT
Looking to swap this over to a 2.o LSJ
for race only purpose.. it should work well.. since the tranny./axles/ upgrades are sooo much available
what else would i need to do?
Ryan
Old May 20, 2010 | 06:41 PM
damien's Avatar
wiring harness/ECU.
100% not worth it
elecblue06's Avatar
hmm honestly i'd look into getting custom axles and make the F35 tranny work with your current car .. you have better tech and larger displacement
Old May 20, 2010 | 08:05 PM
hello
I can kinda see both sides..
I want something for time attack.. Power to weight..
I also want something where way way way more parts are for sale
the axles/trans are junk on a 2.4..
any other comments.. also
ANYONE done this swap or tried?
Ryna
Old May 20, 2010 | 08:15 PM
SS33's Avatar
To the best of my knowledge nobody has swapped an LSJ into a G5 or any other non SS/SC Cobalt.
I would recommend, like elecblue said, looking into just swapping the F35 trans and keeping the 2.4 block. Keep your VVT and extra displacement, and boost her
I don't know if anyone has done the trans swap before, but I would think it would be much more cost effective and worthwhile in the end.
my .02
Old May 20, 2010 | 08:34 PM
elecblue06's Avatar
my .02
someone just swapped an LSJ into an old cavi.. that being said .. they went full standalone / distributor system
also
the F23 tranny isn't junk.. nor are the axles.. zzp has taken the axels to 360 whp
if you want find a F35 with LSD and get the spacer made/ new clutch and flywheel so you can run the F35 on the 2.4.. then get a set of DSS axles if you're scared of those.. and boost the car
Old May 20, 2010 | 08:43 PM
Spins All Day's Avatar
The only thing I can advise would to buy a new car.
Why would you want a Cobalt as a race car anyways.
Last edited by Spins All Day; May 20, 2010 at 08:43 PM. Reason: Automerged Doublepost
Old May 20, 2010 | 08:44 PM
elecblue06's Avatar
the only thing i can advise is for you to GTFO
Old May 20, 2010 | 09:21 PM
skatin_boarding's Avatar
haha leave him alone his name is spins all day cant be the brightest. j/k
Old May 20, 2010 | 09:24 PM
Projekt's Avatar
Ryna
you'r way better off supercharging or turbocharging your current 2.4L
power to weight? i dont understand.
are you comparing the weight difference between the LE5 and LSJ?
Old May 20, 2010 | 09:36 PM
2.2 ecotec
OK
my car is pretty modified.. and a few problems i had with it was making power, overheating, custom tuning, axles, transmisson
with a 2.0 swap all the parts are available.. I want more consistant power..
I had a 2.4 garrett turbo, carrillo rod/wiseco piston, the whole 9 yards..
i have redid my car.. it used to be a GM sema project vehicle..
what kind of power are 2.0 GMPP stage 3 making??
Ryan
Old May 20, 2010 | 09:45 PM
Dainslaif's Avatar
Under 300. If you built a 2.4 and threw a snail on it you should be well above that already.
Old May 20, 2010 | 10:00 PM
swap
i dont think you understand.... I dont want custom.. it should be a easy swap
I want off the shelf products..
Ryan
Old May 20, 2010 | 10:16 PM
Projekt's Avatar
Ryan
like most people in this thread, no one understands really what the **** you want
Old May 20, 2010 | 10:40 PM
jonxxxedge1's Avatar
if you dont want custom, the swap isent possible. if it was simply bolt on bolt off, so many other people would of done it already.
Old May 20, 2010 | 10:45 PM
SS33's Avatar
Ryan
So you want an SS/SC, you bought a G5 GT, wrong car?. "Custom" is your only option. It will not be an easy or cheap swap. fact
Bolting the motor/trans and related parts into your car is one thing, that part you could call easy. However all of the required corresponding components would make the cost and work involved just not justifiable.
We're trying to give the most reasonable solutions to your goal, take it or leave
If you can be more specific about your exact expectations and end goals we can be of more assistance
Old May 21, 2010 | 12:27 AM
hello
i really just want something like the TT cobalt.
i thought I could swap it over, and use the GM stage 3 tune? is that correct?
Ryan
Old May 21, 2010 | 12:35 AM
G11's Avatar
G11
i got a ss/sc trans if you are interested in the trans swap...only 32,000 on it, fluids were clean! pm me if interested
Old May 21, 2010 | 01:47 AM
Old May 21, 2010 | 01:53 AM
mrsilent13's Avatar
i read about an lsj to lnf swap....required every lil harness and sensor to be swapped......everything electrical....so a donor car is def required
or like said before...u can go full stand alone
Last edited by mrsilent13; May 21, 2010 at 01:53 AM. Reason: Automerged Doublepost
Old May 21, 2010 | 02:04 AM
SS33's Avatar
I just don't get this. By the time you factor in the cost of the LNF and all the harnesses, sensors, etc etc etc you are talkin some serious coin
For that you could make the LSJ bullet proof, build a monster head and slap on one hell of a snail.
Makes no sense to me. Why not build what you have, no need to re-invent the wheel
Old May 21, 2010 | 02:05 AM
Nighthawk243's Avatar
1) The LSJ/F35 swap to a G5 isn't exactly a feasable/cheap project. You'd be further ahead just buying a used SS/SC and just doing the bumper swap to turn it into a G5.
2) If you're gonna keep the G5, the LE5 and F23 are more than capable of holding power. The LE5 is good for a respectable amount of power, and the F23 would only really need a better clutch.
Old May 21, 2010 | 02:06 AM
mrsilent13's Avatar
well what i heard was that the lnf was totalled....but everything mechanical was in good working order...then they found another shell and swapped everything over...including interior...and voila...an lnf transplanted into an lsj...and watever was left over from the lsj was sold
Old May 21, 2010 | 02:08 AM
It isn't impossible, but it can become a very expensive project if you don't do all your own work.
Old May 21, 2010 | 02:09 AM
SS33's Avatar
links to a build thread or anything? I'd love to see all the work that went into that process.
I guess if you could get the parts cheap enough, and do all the labor yourself.
Paying a shop for this would be unreal
