2.0L exhaust removal question
Old Sep 8, 2007 | 01:31 PM
anthonyS88's Avatar
i want to buy a catback exhaust for my car. im debating on the megan catback or the gmpp catback. now i know most people cut the factory exhaust to take it off the car, i was wondering is there any way i can take it off without cutting it, incase i buy the megan one and i have to go back to the dealer i can just throw it up on the lift where i work and swap the stock exhaust back
if not i may just get the gmpp
thanks
-Anthony
Old Sep 8, 2007 | 01:37 PM
M88ArRamadi's Avatar
You need a lift to take it out in one piece.......
Old Sep 8, 2007 | 01:47 PM
anthonyS88's Avatar
i work in a mechanics shop, i have axcess to a lift whenever i need one so it can be taken off in one piece? nice
Old Sep 8, 2007 | 08:05 PM
anthonyS88's Avatar
wow one person... thats not very re-assuring lol
Old Sep 8, 2007 | 08:20 PM
Stouffer's Avatar
From what I have seen and read I don't think there is enough play to get off in one piece.
Old Sep 8, 2007 | 08:24 PM
anthonyS88's Avatar
i hope i can get it off somehow
Old Sep 8, 2007 | 08:25 PM
Doc's Avatar
Doc
You need a lift so the rear axle can drop far enough.
Old Sep 8, 2007 | 08:36 PM
anthonyS88's Avatar
thats no problem so im guessing it can be done then... has anyone done it?
Old Sep 8, 2007 | 08:40 PM
halfj99's Avatar
yeah, like they said drop the axle enough
Old Sep 8, 2007 | 08:44 PM
joeworkstoohard's Avatar
yeah, it can be done, but take this in mind.
if you order one from GM, it comes as an axle back part to be welded on.
in other words, it is, like any real exhaust, meant to be welded on/cut off.
Old Sep 8, 2007 | 08:58 PM
anthonyS88's Avatar
im just getting the meghan exhaust one. i like the way it sounds the gm one is too quiet and the price is right
Old Sep 8, 2007 | 08:59 PM
campo165's Avatar
you mean order a stock? because i thought the gmpp was designed like the rest; a bolt and gasket at the axle point of the car so that you dont have to weld.
Old Sep 8, 2007 | 09:05 PM
GULLABLE0NE's Avatar
thanks
-Anthony
the tech that put on my gmmp exhaust said he had to cut the stock exhaust to get it out. according to him the only other way the get it out besides cutting it is removing the rear axle or something like that. maybe a ploy to get more money but thats what i was told. good luck either way
Old Sep 8, 2007 | 09:07 PM
anthonyS88's Avatar
i do all of the work myself so its no big deal dropping anything.
Old Sep 8, 2007 | 09:16 PM
Afterwind's Avatar
I work at a dealership and I installed my GMPP cat-back by myself. It would be an extreme waste of time if you plan on removing your megan catback and re-installing your stock exhaust everytime you take it to the dealership. There is not enough clearance the way it sits so you will have to drop the rear axle. Not worth the time: my two cents.
Old Sep 8, 2007 | 10:11 PM
anthonyS88's Avatar
i have to drop the rear axel to install the exhaust? im just going to cut it off i guess
Old Sep 9, 2007 | 02:20 AM
Doc's Avatar
Doc
You can take it off in one piece, its just much easier to cut it. I've taken two of them off in one piece and with one I left the wheels on and the other they were removed and I disconnected the rear shocks to allow the axle to drop. The wheels actually made it easier.
The GMPP cat-back is a bolt-on piece and takes longer to get the parts together than to actually install it
Old Sep 9, 2007 | 03:17 AM
SSBOOST's Avatar
I've done it and installed GMPP exhaust with a jack. Actually 2 jacks and it took like 20-30 mins.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
jas09ss
Sep 26, 2015 01:06 PM
