2.2 dp on a LSJ?
Old Apr 12, 2009 | 02:00 PM
ikeryder13's Avatar
2.2 dp on a LSJ?
Will this work? I got a ref ticket and i cant pass smog with a hahn catback so i figured i would also swap my lsj dp for a 2.2 dp with 2 cats... it would be cheaper
Old Apr 12, 2009 | 02:04 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you cant pass smog with a hahn cat-back? its after the last emissions control device. it should barely alter emissions.
Old Apr 12, 2009 | 02:06 PM
ikeryder13's Avatar
well i am having problems with my throttle body could that be the reason?
the hahn is all i have left on the car besides my stg 2
Last edited by ikeryder13; Apr 12, 2009 at 02:06 PM. Reason: Automerged Doublepost
Old Apr 12, 2009 | 02:09 PM
BLAZIN07SS's Avatar
I'm too JDM for you
did you happen to get the 5 gas readings? i could help you out if i knew them. if you are having problems with your throttle body it could be causing a rich or lean condition increasing hydrocarbons, altering carbon monoxide, possibly increasing NOx, altering co2 and o2 levels
Old Apr 12, 2009 | 02:16 PM
ikeryder13's Avatar
yeah my throttle body is bad... i keep throwing a code that sends me into limp mode but i just clear it with my obd2 scanner... then sometimes when i start it in the morning it almost dies and wont fully stay at idle... i am pretty sure i need a new throttle body.. but not only that but with the hahn i didnt pass my decibel test either lol
Old Apr 12, 2009 | 03:25 PM
tdipowered's Avatar
maybe you just need to clean it or the sensor...
Old Apr 12, 2009 | 03:48 PM
ikeryder13's Avatar
i already cleaned it and it still does the same
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 28, 2015 12:51 PM
