2.2 turbo
2.2 turbo
I was thinking about building 2.2 turbo motor. i was wondering what i would need to make this possible. would the 2.0 tranny bolt up to the 2.2. could i somehow use the 2.0 ecu on the 2.2 so that i have the ability to still use hptuners. And would i need custom mounts for the engine. Anything else that im missing would help alot. thanks.
I'm selling a built up 2.2L motor if you're interested. But as for the transmissions mounting up, I believe they do. No on the custom motor mounts I think and the swap of the ecu I don't think would be possible , but if it is, it'd be a PITA to do. Someone please correct me if I'm wrong.
you don't need the 2.0 tranny, just throw in an Exedy or Spec clutch into the F23 and it will handle the power you need.
as far as tuning goes you will either need to work with a piggyback or go standalone...
