2.4 Block
Old Dec 4, 2007 | 05:46 PM
VaderSS's Avatar
2.4 Block
Hey guys, haven't been around for a while and I know this is a random question if it hasn't been asked before, but I know some compaines engines internals are interchangable. Can I swap a 2.4 block into my 2.0? Is the intake side of the head interchangable with the blower? In many chevrolet instances, engines of different displacement share a similar block and head(s). Leave the flaming (if any) to a minimum please
Old Dec 4, 2007 | 06:43 PM
chevytech007's Avatar
Yes you can! Just run the lsj head on the le5 block and you will be ok.
Old Dec 4, 2007 | 07:32 PM
VaderSS's Avatar
awesome. now i just have to get my hands on a 2.4 block. you don't know how much of a difference it will make do by any chance do you? i mean, obviously a significant ammount.
Old Dec 4, 2007 | 08:33 PM
black07ssc's Avatar
What are you asking? How much more power your gonna get with a 2.4 block?
Old Dec 4, 2007 | 09:30 PM
But If i remember right the clutch is different in the LE5 motor? it has a thinne flywheel I think.
Old Dec 4, 2007 | 09:57 PM
Sharkey's Avatar
iirc, the 2.4l vvt eco has the same clutch and tranny as the 2.2l.
there are quite a few differences in the ecotec bottom ends. the 2.0l is the only one with an oil cooler, the other blocks do not have provisions for it. in the bottom end, the crank is stronger in the boosted versions, also 8 bolt flywheel vs 6 bolt for the 2.2/2.4. there are also forged pistons and oil squirters to cool the pistons.
if your looking at doing an engine buildup and wanting the extra displacment, just use a 2.4l crank in an lsj block. as long as you dont go passed 500hp you will be ok. custom pistons may be needed with the extra stroke though.
Old Dec 5, 2007 | 01:15 AM
VaderSS's Avatar
well, I guess the easier way to go would be just to get the 2.4 crank then with a set of forged pistons, and will "bolt" in(for lack of a better word)? This is going to be the first internal mod I have done so far and I want to ask a bunch of questions. It's not going to be for another couple of months at least, but I want to have my facts straight. What kind of a hp/tq gain am I looking at with this?
Old Dec 5, 2007 | 11:35 AM
IonNinja's Avatar
thats going to be alot more work then you think. check out fullthrottle's build up thread on the redline forums. he has done exactly what you were thinking of (2.4 bottom end w/ LSJ head) and it certainly doesn't seem like a straight swap. with the tranny as well I believe he needed a custom flywheel and clutch among other things to bolt the LSJ tranny to the LE5 block.
I would either swap the 2.4 complete and build from there or build your current 2.0 for simplicity sake.
Old Dec 5, 2007 | 02:49 PM
VaderSS's Avatar
you're talking about a 2.4 block correct? i didn't really follow what you were saying. i'm talking about using a 2.4 crank with forged pistons, but it seems like you're talking about using a 2.4 block, but i may have read it wrong.
Old Dec 5, 2007 | 03:14 PM
Jackalope's Avatar
Ahhhhhh..... I see your a believer in the "No replacment for displacment" school of thought. Well your 100% correct! Bigger is better! Always has been,always will be. True this may **** off some 2.0 owners to hear but the 2.4 having a larger displacment will make more power if built similerly to the 2.0. Its just basic physics, the larger the cylinder, the larger the piston area, the more that can be cramed into it, the bigger the bang. All that translates into MORE POWER.
There are a couple SC 2.4's and turboed 2.4's running around they'd be the guys to talk to.
Old Dec 5, 2007 | 03:28 PM
I agree
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
