2.5 or 3 exhaust, Simple
Old Jan 23, 2009 | 01:34 AM
fzn14's Avatar
Currently running
3' catless dp
60lbs Inject
2.8 Pulley
basic tune
Will be running Injen Intake as well, Now as far as my Furture mods i MIGHT drop to a 2.7 with a H/E as well, So with that being in mind Which would be better? i have heard 3' but i have also heard those are bad on our cars, Now my thinking is that on a NA car 2.5 is GREAT, But since we have F/I car wouldnt 3inch be better since your flowing much more air?
talk
Old Jan 23, 2009 | 01:35 AM
EXsoccer1921's Avatar
i think you'll be alright with a 3"
Old Jan 23, 2009 | 01:38 AM
red06SC's Avatar
2.25 is great for NA
2.5 up to 300hp
3 above that
Old Jan 23, 2009 | 01:40 AM
fzn14's Avatar
i thought so to, and plus with have a 3' Catless DP wouldnt that bottleneck the system
Old Jan 23, 2009 | 01:42 AM
red06SC's Avatar
Stay with a 2.5 if you're only going to be doing a 2.8. Get an aftermarket header/dp and an over-axle-back.
2.5 up to 300hp
3 above that
you're source???
Old Jan 23, 2009 | 01:43 AM
Zach06CobaltSC's Avatar
Run a 3inch exhaust.
Old Jan 23, 2009 | 01:44 AM
red06SC's Avatar
you're source???
search
The stock 2.5 exhaust flows well up until 300 hp, only bottlenecks are in the dp and axle back.
Old Jan 23, 2009 | 01:50 AM
A 3inch exhaust will lower your boost which is GOOD. Remember, boost does not equal power, and to much boost can be a bad thing.
Take it from someone who is running 3inch exhaust and putting down over 325whp on the stock m62, run a 3inch exhaust, you won't regret it!
sloancallaway's Avatar
It basically depends on where you want to go from here... you could probably get away with a 2.5 catless If you wanted to... i would go 3 inch would probably be ideal though... you wont make that much power unless your running N2O but i think you will be happy with the results
Zach06cobaltsc is the 325WHP on your 50 shot?
Old Jan 23, 2009 | 01:54 AM
fzn14's Avatar
See i dont "wanna just get away" I want a good flowing system that doesnt sound overly bad as well and flow with no issues, If i run lower boost who cares. i want the stock stuff No if ands or buts about it, Its good for what it is, But not what i want.
Old Jan 23, 2009 | 01:59 AM
Dont blame you go 3 and i think you will be satisfied
Old Jan 23, 2009 | 02:00 AM
ajjaro's Avatar
im gonna be running a 3" vortex header with 3 inch downpipe and 3 inch exhaust. is it going to be louder then the legal limit?
Old Jan 23, 2009 | 02:03 AM
oh and i would do headers and catless dp but thats up to you...
sorry posted before i saw yours sounds good but as for the legal limit i dont know sorry bud good luck
Last edited by sloancallaway; Jan 23, 2009 at 02:03 AM. Reason: Automerged Doublepost
Old Jan 23, 2009 | 02:04 AM
fzn14's Avatar
already have the catless DP....
red06SC's Avatar
http://www.youtube.com/watch?v=_paE9sjjbzk
http://www.youtube.com/watch?v=6AQReF_T7Uo
oh yeah
Old Jan 23, 2009 | 02:24 AM
ajjaro's Avatar
why do you think i bought this setup lol,
if i put a silencer in my muffler, will it quiet it down enough?
does anyone have information on silencer's for this setup???
Old Jan 23, 2009 | 10:27 AM
ShortStack's Avatar
Yes, it is.
Yes, a 3" will allow allow for better flow, but at a slower velocity.
The faster the exhaust comes out, the better...
Someone with a 3" setup, and a cold air, who had a 3" exhaust, dyno'd 8 - 10 more when he switched over to his 2.5"... he did this on the same day, not at different times or anything.. a good solid before and after test.
the 300 mark isnt set it stone, it just just a good place mark of where the 3" would start being more beneficial than a 2.5". I think that number should be a wee bit lower, around 270 or 280... but thats all up to you.
Old Jan 23, 2009 | 02:36 PM
ajjaro's Avatar
so your saying i should have a 2.5 inch muffler? instead of a 3?
Old Jan 23, 2009 | 02:40 PM
ShortStack's Avatar
make sure you dont confuse muffler with catback.
Id stick with a 2.5 if i were you.
Old Jan 23, 2009 | 02:44 PM
D4u2s0t's Avatar
just because you're putting down a certain hp # doesn't mean it's the best setup. plus, you hp #'s put you in a different category.
3" will be too big. stick with the 2.5". on a 3" you will lose some velocity especially with the bigger downpipe.
Old Jan 23, 2009 | 02:53 PM
ajjaro's Avatar
reall/, so injen cai, 3 inch downpipe vortex header, 2.5 inch catback, is the best setup with ottp stage 1 meth injection 60/40 tuned mix, tb, h/e, dual pass endplate? are you sure?
Old Jan 23, 2009 | 02:55 PM
ShortStack's Avatar
yes... if you are planning to go faster (smaller pulley, things like that)... id do a 3" so you dont have to buy twice, but it would be a less kick in the pants until then.
Old Jan 23, 2009 | 02:58 PM
ajjaro's Avatar
well im in a conastant debate over 2.7/ 2.8. the way i drive i think the 2.7 will be just as reliable with the cooling mows i'll buy, but i would have to get a custom tune, i'll be better off with a 2.8, whats the difference anyway 5whp?
Old Jan 23, 2009 | 03:01 PM
ShortStack's Avatar
the difference is how much harder the pull will be... youll be fine with a 2.7... promise.
plus it will be that much more fun.
