2.5
what are you reving to? at 8k ur past the blowers peak rpms
on the 2.5 that is.. only reason i really stuck with my 2.6.. but in for results
im totally allowed to make a boring post. hahaha
as far as rpms go ill be under 7500, just cause im not setup for the high revs yet.
next winter will be cams/springs. and maybe a block
stock block will handle it just fine its the knock you need to worry about
yes it will but it wont lower combustion presure
Last edited by mrbelvedere; Jan 15, 2011 at 05:11 PM. Reason: Automerged Doublepost
