2.5
Old Jan 16, 2011 | 10:29 AM
glen229's Avatar
damn im working a 24 that day, would like to see the beast finally go
Old Jan 16, 2011 | 10:34 AM
freakta's Avatar
me too hahaha. fred has the im off the car if you get a chance you should check out how i made it
Old Jan 16, 2011 | 12:13 PM
tityrous's Avatar
is your car still apart?
Old Jan 16, 2011 | 12:24 PM
SS4ME's Avatar
Why 60# injectors with your TVS set-up? I thought 80# injectors were the way to go with a TVS set-up. Any E85 in your area?
Old Jan 16, 2011 | 12:45 PM
SuckMyBalts's Avatar
You can run 60s just fine on 91-93, however I am pretty close to maxing them on the 2.9 that I am running now. Shortly I will be on 98lbers and e85 though, just waiting for it to warm up a bit and it to go back up to roughly e80. Ethanol blends change in the winter, some drop down to the e75 range. This doesn't change detonation factors all that much, but it's a pain having to re dial in the fuel trims whenever you find a station with a different blend or every 6 weeks when it increases / decreases lol.
Old Jan 17, 2011 | 05:41 PM
zrated89's Avatar
Originally Posted by mrbelvedere
stock block will handle it just fine its the knock you need to worry about
yes it will but it wont lower combustion presure
and the chance of KR goes up drastically with the increased combustion pressures. I know he has an air to air but we shall see
Old Jan 17, 2011 | 06:45 PM
mrbelvedere's Avatar
will there is no chance it will but with spot on tuning there shpuldent be a problem
Old Jan 18, 2011 | 10:48 AM
freakta's Avatar
no e85 near me... the 60's werent very closetomaxing out. and with the brfpr they will be fine. and impushing a ton of meth so itsnot a big deal. my car runs cold theaits are cold so thereisntmuch knockto speak of. we will see what the 2.5 brings. sometime this week keeping our fingers crossed
Old Aug 8, 2011 | 01:12 AM
Flatgod's Avatar
What ever happened with this?
Old Aug 8, 2011 | 11:09 PM
freakta's Avatar
stilll no results. its been over a year since ive driven my car.... its just a waiting game. kinda sucks but if you want things done right ...
Old Aug 9, 2011 | 12:56 AM
  #36
Flatgod's Avatar
My 2.5 hopefully will be in this week. Has anyone run a 2.5?
Old Aug 9, 2011 | 12:59 AM
  #37
Omnigear's Avatar
Originally Posted by freakta
finally got it. cant wait to see what it does
pictarz or it didnt happen =p
Old Aug 9, 2011 | 01:27 AM
  #38
Ph3lix_004's Avatar
lol it didnt happen^^
Old Aug 9, 2011 | 02:02 AM
  #39
InfraRedline's Avatar
Area47 did for a little while. Gains were minimal from the 2.6, but the restriction at that point wasnt looked into in too much depth.
Old Aug 9, 2011 | 11:52 PM
  #40
freakta's Avatar
i got the 2.5 its on the tvs right now. what i dont have is the car tuned.
Old Aug 10, 2011 | 11:07 AM
  #41
ebristol's Avatar
I want to run a 2.4" on a M62. It would be cool to see the TQ numbers the same as the HP.
Old Aug 10, 2011 | 09:32 PM
  #42
JCobalt's Avatar
I'm about to go to a 2.5 as well on my tvs. Just not sure if I should run a 5gph-7gph nozzle. Right now I run the 3gph. I run the spacer between the blower and manifold so the nozzles a little closer than most people. Not sure if the distance makes a difference or not though, I just don't want it to puddle in the manifold.
Old Aug 11, 2011 | 01:32 AM
  #43
freakta's Avatar
ive got 4 1gph nozzles in the intake mani aimed right at the intake runners in the head. i dont get puddles and its a nice setup for the car to have. with just a base no timing no meth nothing pushed hard run it made more hp than before with everything on, so its gonna be pretty fun
Old Aug 11, 2011 | 01:30 PM
  #44
JCobalt's Avatar
Ok so the 5gph should be plenty
Old Aug 11, 2011 | 01:36 PM
  #45
jonathan923's Avatar
interesting, in for results.
Old Aug 12, 2011 | 12:58 PM
  #46
freakta's Avatar
ya that should be enough. i acutally would love a bigger tank mine is going to run out all over the place.
and yes im in for results as well
Old Aug 24, 2011 | 01:29 PM
  #47
freakta's Avatar
ate, had an idle problem. the intake manifold was not true, sso we fixed that. then ran the car on the dyno.
then the resonator blew out.
so i need a new one
Old Aug 24, 2011 | 09:20 PM
  #48
JCobalt's Avatar
Did you get any decent results while you were on the dyno. I got my 2.5 and 5gph nozzle last week just need the pnumolic( probably didn't spell that right) intake gasket and a Saturday off so that I can put it on and tune.
Old Aug 25, 2011 | 12:45 AM
  #49
freakta's Avatar
took out all the timing didnt run meth and didnt push the car all the way and made more than the car ever had
Old Aug 25, 2011 | 01:08 AM
  #50
Bika's Avatar
Fail Less.
wut? no timing? lol
sounds awesome though.
